Tumble dryer 'Smart lamp' pcb
  • notallbad
    • Oct 2012
    • 1190
    Re: Tumble dryer 'Smart lamp' pcb
    Sorry 'redwire', I hadn't intentionally ignored your post requesting the dryer model or board p/n, had just missed it somehow? unlike me to reply or post a conclusion.
    Of course, now I don't remember but shall update if/when I come across them again.
    regards
    rob
    • notallbad
      Heat pump tumble dryer regas
      by notallbad
      Just wondering if anyone has successfully attempted a re-gas on a heat pump tumble dryer.
      The dryer currently in question runs on R134a.
      The dryer has been completely stripped down/cleaned/tested and re-assembled however there is no heating/cooling effect so working on the assumption it requires re-gassing. Of course, its likely theres a leak which would require soldering or even the possibility that the compressor has an internal fault even though it is running.
      I was thinking of getting a car aircon regas kit or probably easier but slightly dearer an hvac...
      07-16-2023, 01:27 PM
    • Petros_Z
      candy tumble dryer (evoc 981 at-s) Component 738
      by Petros_Z
      Hello. I have a board of a candy tumble dryer (evoc 981 at-s).
      It does not give an error but it keeps drying even without load. It has 3 ntc. Two are for the clothes and one for the compressor. I measure them and they look ok. I went to the board to measure the voltage given to them. It gives about 4v and it is going down as the ntc value going down.
      Because I wanted to measure more easily I tried to solder wires on the board. Probably I manage to destroy the component of the title. It looks like as a smd resistor. Hopefully there were other two same components. I disorder them and...
      01-04-2025, 02:17 AM
    • spleenharvester
      Beko Tumble Dryer DTLCE80021W cutting out/tripping RCD
      by spleenharvester
      This dryer is several years old and has previously had a new motor cap. Currently it's behaving erratically - sometimes it finishes the cycle fine, other times it cuts out after a random period of time (just stops with no LEDs as if it has finished normally), and occasionally it trips the RCD. There's always steam coming off the clothes at the time it cuts out.
      Going to pull it apart tomorrow, before I lob a new heating element at it is there anything else worth checking? It's £70 for a new heating element and the whole machine only cost £180 to begin with...
      Cheers
      12-16-2024, 03:36 PM
      HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i7-9700 Specification for Upgrade or Repair
      This specification for the HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch boardview and ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
      09-12-2024, 02:30 PM
      HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i5-9500 Specification for Upgrade or Repair
