Anyone repair appliances? GE ice maker issue
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: Anyone repair appliances? GE ice maker issue
    Originally posted by stj
    maybe they didnt plan for what happens 10 or even 20 or 30 years later.
    This brings up an interesting question: how long should things plan on lasting? Note that designing for a longer lifespan adds to cost -- will most folks be willing to pay that additional cost?
    [Of course, this depends on the market: designing a cell phone to last 10 years would probably be overkill. OTOH, designing a kilowatthour meter to only last 10 would be totally impractical from a business standpoint.]
    TV? Microwave oven? ECU? <shrug>
      • 31019
      that's an end-product question.
      components should be made from stuff that doesnt age if possible.
      you dont know if they will end up in a ships radio, or a childs toy.
      and this is not an intentional problem, they probably didnt know the resin would crack - it doesnt crack in other electronics applications.
      it may be a side-effect of it being translucent.
      • redwire
        • 3910
        I sent an email to Vishay asking why they still sell these crap Rifa PME271 series.
        OP's fridge should be OK as there are no X-caps on the ice-maker?
        It's 50/60Hz transformer-powered (no SMPS) and I think the caps are just to snubber the triacs. So a short would just leave the water solenoid on...
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          Components are designed with end products in mind. You don't expect every component to be "top shelf" -- even if used in a piece of disposable kit?! Hence 1000hr and 5000hr caps, e.g.
          No, that's the engineer's job -- to SELECT (specify) components that are appropriate to the design at hand.
          In many decades of design, I've only once been tasked with a design specification that clearly specified a "30 year lifespan". Virtually everything else was left to my discretion as to the quality of components I'd choose to meet the performance and price targets (longevity not being mentioned).
          [I've only recently been tasked with designing consumer kit; most prior was industrial, commercial or medical]
            • 31019
            these specific caps used to be considered "the best", the type of part you choose for your space program or sound studio - they wherent cheap!
            • redwire
              • 3910
              ... No, that's the engineer's job -- to SELECT (specify) components that are appropriate to the design at hand.
              Nah- Product management gives a design cost-target to engineering. No point in building something that costs more than your competitors.
              Look at PC power supplies. Designed to the penny and every electrolytic chosen to weigh overall cost verses lifetime.
              GE, Crosley, Frigidaire, Maytag, Kenmore, Whirlpool etc. are no different. These appliances are designed to the penny but don't go far past their warranty date.
              GE warranty seems to be 2-5 years on select parts.
              • petehall347
                • Jan 2015
                • 4426
                • United Kingdom
                #27
                i blame the bean counters ..
                • rounin
                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                  by rounin
                  🛠 Original Issue
                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                  04-19-2025, 01:18 AM
                • ugamazing
                  by ugamazing
                  12-17-2024, 07:05 PM
                • ahmarzo
                  Acer laptop battery draining issue
                  by ahmarzo
                  Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                  Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                  08-02-2025, 06:39 AM
                • elmark
                  HP 15-cw1002ua strange keyboard issue
                  by elmark
                  HP Pavilion 15-CW1002UA
                  S/N 5CD0251CBC
                  P/N 7KE54EA
                  Hello guys!
                  I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                  It powers on OK and has no other issues except the following:
                  • CAPS LOCK does not work at all
                  • Fn button toggles Flight Mode
                  • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                  • (with SHIFT pressed: 't%' and 'y^' respectively)
                  I initially thought it was a keyboard malfunction (internal short, etc.),
                  but when I press and hold...
                  06-27-2025, 01:10 AM
                • Simone Vergani
                  Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                  by Simone Vergani
                  I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                  To assist with troubleshooting, I'm attaching two power circuit schematics:
                  • Power
                  03-05-2025, 02:25 PM
