Bad Caps on a GE Power Control Board Refrigerator
    • Jul 2011
    • 6070
    Here is the story....>>>
    Tuesday of this week I got a text from some good friends of my son
    We had a really bad thunderstorm that came throught made the power go ON and OFF a few time .....>>>
    Well after the power came back on for good the Refrigerator would NOT turn back ON and run
    This is one of the newer models that has a micro controller that controls everything
    This Refrigerator is DEAD no LIFE other than the light in side the frigate part and the light in freezer
    So took a look at the control board and what do I see is a TOP246YN offline IC switcher on this board and a BYW29-200G UL fast 200 v 8A Diode and two caps next to the Switcher IC one was a 47 uf no ESR value at all 1 uf 50 ohms that is not a misprint
    Replaced the IC switcher and the Diode and the two caps
    Put the control board back in the Refrigerator and everything came back to life
    BTW this control board retail for $190.00
    I got all the part from Digi-key for $15.00 and ordered 3 switcher IC and 2 diodes It took about two hours pull these parts and change them because they coated the board with what look like hot glue
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Bad Caps on a GE Power Control Board on a Refrigerator
    You forgot the most important thing! What brand were the caps that failed?
    Muh-soggy-knee
      • Jul 2011
      • 6070
      Re: Bad Caps on a GE Power Control Board Refrigerator
      It took a little while to find the box that I had put them in
      The brand name of the two caps are the same
      Ltec SM 85*C 4601D this was on the caps
      The other caps on the board were different brands I did not change them because of all the hot glue on this board
        • Jul 2011
        • 6070
        I know that this is a very old post but I recently talked to the person that I had fixed his refrigerator and he told me that it was still working good after this repair
        • R_J
          • Jun 2012
          • 9622
          I have seen this many times, it was likely just the power being turned off that it did not turn back on. As long as power is applied, the ic's vcc stays up, even with the 47µf being very low. But when the vcc cap is that low it will not charge up and start the ic again. Ask him to unplug the fridge for 5 min and see if it starts back up again.
            • Jul 2011
            • 6070
            That is what I had done before I came to the conclusion that there was something wrong with the controller board
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • Yanleb
              LG 60PK550 Logic Control Board EBR63450301
              by Yanleb
              Hi all, I just want to share the repair of my 60PK550-UA TV set.
              The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
              But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
              All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
              C57: 3.30V
              C61:...
              07-20-2023, 12:38 AM
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • black6host
              Replacement caps for Samson Resolv studio monitor 65A Amp board.
              by black6host
              Good day!
              I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
              I'm going to replace the caps and I'll be the first...
              02-06-2024, 08:22 PM
