Alright, I have an 0603 resistor kit on the way.
Hoover FM216LI cordless vacuum refuses to charge
Finally got a new resistor soldered. It's very small so was difficult, I stopped trying to make it better aligned since it is practically attached.
I verified with multimeter that it's connected to the traces.
After that I plugged in the charger and the 3 LEDs turned on, I think it blinked slightly different than before the resistor, but immediately all 3 LEDs stayed solid which is as if charging is complete, just like before the resistor.
I was disappointed, I thought there still was a problem...
I replugged the charger many times and same thing.
I turned on the motor and it spun up and immediately had only 1 LED light and blinking as if battery is running out then motor stopped, although I previously manually charged it to 24V and before replacing the resistor the motor would stay on and with 3 LEDs showing full charge.
I repeated plugging charger in and out, and trying to spin the motor (it didn't try to spin again unless I plugged the charger in and out, it's probably related to a feature that once voltage cut off has been reached you can't turn the vacuum on unless charged has been plugged in and out first (but in this case the controller for some reason falsely thought battery was empty)), and then all of a sudden it started charging again!
Maybe the controller needed time or many tries until it cleared a fault and was happy again? IDK... Anyway now it charges so all good.
Thanks CapLeaker for advice.Comment
First of all you need to know if the battery pack cells are good or not please show a picture of the battery cells so I can see what type you have
But basically you need to know the exact voltage of each battery cell under a load
Use the same load ( incandescent light bulb preferably) on each battery cell if the battery cells are more than 0.250 volts ( run the test for at least five minutes at a minimum ) different then you might be having an issue with the BMS protection system circuit locking up and refusing to turn on properly
Now if your battery pack cells are unbalanced then you might have a bad case of end of life syndrome issues and there is no cure for it other than replacing the battery cells all of them reason being that the other battery cells might also be close to end of life syndrome but are not to the point of self discharging
There is a test that will verify if this is the case fully charge each battery cell to it's recommended voltage and then let the battery pack sit disconnected from the device for 30 days and recheck the battery voltage on each battery cells and the voltage should not have dropped more 0.500 from where you left it but let the battery pack sit for 3 hours before you take the voltage reading so the battery voltage becomes stable for accurate reading
How these BMS protection devices work is that if the voltage is different more than a certain amount it locks up the charging circuit if the voltage goes beyond 4.2 volts depending on the type of battery cell used it could be 3.8 volts or a little lower than that but in general if any battery cell reaches this voltage limit it turns off the charging current circuit or if a battery cell is below 3.volts or lower depending on BMS protection parameters to protect the battery cells from damage and from it selfLast edited by sam_sam_sam; 06-12-2025, 06:42 PM.Comment
Thanks sam_sam_sam,
The vac is already assembled, but I saw before that the cells are Samsung ICR18650-22P.
I already completed full charge after replacing the resistor and I monitored the battery voltage during the first charge and it stopped before 25.2V I think the last reading I got before it stopped charging was 25.16V then the voltage settled a bit lower, then I vacuumed for probably over 30mins and it was still going and had 1 out of 3 LED left when I turned it off, then I completed another full charge, so at the moment I think it's good.Comment
by jinu_jHi
4. D930 - Shorted Schottkey Diode...-
by mikey5791Hi to all forum members,
Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor... -
I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors... -
by artvandalaiThe resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y3 Photos
by chth96I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
Since then, This AC/DC adaptor have been out of order.
But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
And Is there any possibility that it will suddenly explode as well as to be out... - Loading...
