Grundig High Performance Cyclone Battery Led blinking
  • Nick868
    • Oct 2023
    • 17
    • Italy
    Hello there,
    i've got a a grundig high performance cyclone that seem the board doesn't charge the battery. What should i check? I notice that d6 is very hot
    • Jul 2011
    • 6040
    The first thing you need to figure out is that diode shorted or do you have a short on that part of the circuit where this diode is located at
    • Nick868
      • Oct 2023
      • 17
      • Italy
      The diode is ok and i don't find any short
      • CapLeaker
        Leaking Member
        • 8184
        Under D6 there are a couple of SMD resistors that are looking burnt?
        • Nick868
          • Oct 2023
          • 17
          • Italy
          Yes, it's the first thing that i checked, but the values are ok, one it's 202 2komh and the other it's 103 10kohm (checked on board). I've only 0402 smd resistors and these ones i think they are 0603
            Microsoft Surface Book Surface Book with Performance Base Hybrid (2-in-1) Specification for Upgrade or Repair
            This specification for the Microsoft Surface Book Surface Book with Performance Base Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book with Performance Base boardview and Surface Book with Performance Base schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
            09-06-2024, 08:20 AM
          • LEECH666
            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
            by LEECH666
            Good day ladies and gentleman!
            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
            01-19-2024, 05:46 PM
            ASUS VivoBook Performance Laptop Notebook Pro Specification for Upgrade or Repair
            This specification for the ASUS VivoBook Performance Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Performance Laptop boardview and Performance Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 07:00 AM
          • Flybacks
            Grundig CUC 2401 CRT TV - Brightness is too high
            by Flybacks
            Hello, I'm trying to fix a Grundig CUC 2401 with picture brightness too high.
            The problem seems to be in the brightness voltage supplied by pin 16 of TDA8442 that should be in the 1-3V range instead it is about 3.2V.
            If I manually lower the brightness the voltage goes in the right range of about 2V and doesn't increase but I don't understand why at start up it is set wrong ?
            I've already changed TDA8442, the video output IC TDA3505 and the microcontroller IC811 but it didn't fix.
            The collector of RGB transistors on crt board are about 170V for red and blue but 150V...
            12-30-2021, 07:20 AM
          • YasaCh
            Sony kdl 40p5500 red light keeps blinking 3 times
            by YasaCh
            Hello...
            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
            i opened the back cover no sign of damage on the powery suply or motherboard
            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
            07-07-2025, 11:53 AM
