Blown heated blanker controller. Trying to figure out these smd resistors
  • petehall347
    replied
    at 225 ohms i calculate about 250w .. but the resistance will change as it heats up so cant really calculate it easy
    your tester knows what it is so its maybe good .
  • Widget
    replied
    how many watts is the blanket supposed to be ?
    100w.
    I put it into my new(ish) component tester. Didn't tell me much I don't think.
  • petehall347
    replied
  • petehall347
    replied
ID:	3304600this is how it should be
  • Widget
    replied
    f1 looks like a thermal fuse
    the wonky display might not be helping things
    True. though doesn't look like any legs were broken.
    see what resistance between black and white and blue and brown .
    Blue/Brown = 225ohms
    Black/white = 944ohms
    Originally posted by CG2
    Check the resistances of the blanket and compare it with the good one before you turn to the controller. Some blankets have a sense wire in addition to the heating one, and if that is damaged the controller responds by effectively committing suicide. The blown resistors may be a symptom of a dead blanket.
    Will do, though looks like we might have a receipt here for warranty, so might try getting refund/exchange.
    Originally posted by stj
    are there any more components under those elevated displays?
    none
    Originally posted by harp
    There is a three pin triac near display, but when I see fault like this, where a few resistor disappear and where these was directly connected to controller... first disconnect that leg of ic, and see if you have diode junction reading to any other. .
    i didn't notice that triac .
    You see on bottom pcb trace signature, and on top is black package, combined with 220v heater what else could be...
    https://www.eevblog.com/forum/beginn...=2302253;image
    Thyristor... 2P4M
    Op is lazy... (:-
    Sorry, only saw that components this afternoon & had to Google it.
    someone broke its heatsink off .
    No heat-sink on it. No heat-sink on the working one either. Perhaps there meant to be & without one, it overheating causing as overload of some sort?
  • petehall347
    replied
  • harp
    replied
    Thyristor... 2P4M
    Op is lazy... (:
  • petehall347
    replied
  • harp
    replied
    There is a three pin triac near display, but when I see fault like this, where a few resistor disapear and where these was directly connected to controller... first disconnect that leg of ic, and see if you have diode junction reading to any other. Probably not, and thats is end of story designed to serve newnormal ideas of light green eco ic suicide.
    It is sadly to say in this modern time - make your ovvn controler with discrete riggid parts which you can repair if you need.
    replied
  • CG2
    replied
  • petehall347
    replied
  • petehall347
    replied
  • Widget
    replied
    i cant see any mains switching devices,
    i'm wondering if the numbers are just a display rather than a control.
    and if both fuses are good it may just be a shorted display chip
    it looks like it has a big switch so maybe it just has full power and half power (half wave rectified) to the heater
    Oh, I didn't see/test the white (ceramic) fuse (F1), iirc the glass fuse (F2) tested ok.
    The big (0-1) switch is on/off. The temperature & timer go up to 9 I think via the soft-press gray buttons
    here is a different repair on the same controller . https://jestineyong.com/homemaker-el...ow-rug-repair/
    and here is a pic of how it looks on the front .
    Click image for larger version  Name:	fixing-electric-throw-rug.jpg Views:	0 Size:	92.3 KB ID:	3303766
    Saw that one, pitty it wasn't the same repair I need lol.
    am guessing the middle contacts black and white wires go to a thermistor in the blanket .
    I'm not sure how the wires in the blanket work. There's 4 wires that run into the blanket but none seem to be linked to each when I did a cont test.
  • petehall347
    replied
  • petehall347
    replied
    replied
  • Widget
    replied
    Originally posted by redwire
    OP said it was likely a short between mains and the thermistor, he binned it.
    No, Kurets said that, not me (op) lol. but yes, I'll probably have to bin it.
  • redwire
    replied
  • Widget
    replied
    so it doesnt have a thermostatic switch, just a teperature disply/timer?
    Not sure to be honest. I only know of the on/off switch & buttons to control temperature & timer (s2 & s3).
  • ZixuTech
    Lenovo Yoga 330 11IGM YOGA330_MB_V06 Blown Voltage Reg V3P3A and ENE KBD Controller
    by ZixuTech
    This is a Data Recovery case from Lenovo Yoga 330 11IGM onboard eMMC Sandisk 128GB
    Seems like the device had a power surge. Blown U6002 and went and cracked the die of the KBD controller. I detached the JP6003/4 tracks around U6002 but short still appears around the kbd controller (i believe)
    I havent had a case to replace and reprogram KBD controllers before. How can I get the dump and what tool do I need to use. Is there a process written somewhere? Thanks in advance.
    Let me know if you know any jigs which can recognise these sandisk chips. I wont mind...
    01-01-2024, 10:15 PM
  • reessi
    20v / 2A SMPS for a Battery Charger - Explanation of Blown Resistors Please..
    by reessi
    My friend asked me to replace the wire going from this SMPS 20v adapter to the charger for a 18v Lithium Battery for a drill.
    The cable had frayed and been touching, as a result the 5 Paralleled R200 (0.2 ohm) resistors had blown O/C, they are connecting the main -ve rail to the output wire.
    The output was jumping around 13v and dis-appeared when a load like the charger was connected, they measured 900ohms.
    I experimented by replacing at first a single 0 ohm and then a 2.2ohm in and the output was restored at 21.62v and 21.65v respectively...
    08-22-2024, 08:12 AM
  • master3112
    ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
    by master3112
    I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
    When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
    10-29-2024, 09:32 PM
  • TinkerTron
    Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
    by TinkerTron
    Hey everyone,
    I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
    Instead, here's what's been bugging me so far:
    The schematic...
    03-06-2025, 02:03 PM
  • redbaron1007
    High Power HP1-J600GD-F12S
    by redbaron1007
    I got a High Power HP1-J600GD-F12S on the bench today that was killed by roaches judging by the dead roaches and large brown spots in the housing next to said roaches.
    I was able to identify all the blown smd resistors on the board aside from the one located at R69. I wasn't able to figure out what any of the marking on the resistor was supposed to be and with how little of the marking was left I wasn't able to really make any guesses about what it could be from the surrounding components. It is connected to pin 1 of Q11 (4N65SFA1K) which looks like it is the gate .In the sample...
    09-21-2024, 07:00 PM
