at 225 ohms i calculate about 250w .. but the resistance will change as it heats up so cant really calculate it easy
your tester knows what it is so its maybe good .
Blown heated blanker controller. Trying to figure out these smd resistors
Blue/Brown = 225ohms
Black/white = 944ohms
Check the resistances of the blanket and compare it with the good one before you turn to the controller. Some blankets have a sense wire in addition to the heating one, and if that is damaged the controller responds by effectively committing suicide. The blown resistors may be a symptom of a dead blanket.
none
You see on bottom pcb trace signature, and on top is black package, combined with 220v heater what else could be...
https://www.eevblog.com/forum/beginn...=2302253;image
Thyristor... 2P4M
Op is lazy... (:-
No heat-sink on it. No heat-sink on the working one either. Perhaps there meant to be & without one, it overheating causing as overload of some sort?Leave a comment:
Thyristor... 2P4M
Op is lazy... (:
There is a three pin triac near display, but when I see fault like this, where a few resistor disapear and where these was directly connected to controller... first disconnect that leg of ic, and see if you have diode junction reading to any other. Probably not, and thats is end of story designed to serve newnormal ideas of light green eco ic suicide.
It is sadly to say in this modern time - make your ovvn controler with discrete riggid parts which you can repair if you need.Leave a comment:
Check the resistances of the blanket and compare it with the good one before you turn to the controller. Some blankets have a sense wire in addition to the heating one, and if that is damaged the controller responds by effectively committing suicide. The blown resistors may be a symptom of a dead blanket.Leave a comment:
see what resistance between black and white and blue and brown .Leave a comment:
f1 looks like a thermal fuse
the wonky display might not be helping thingsLeave a comment:
i cant see any mains switching devices,
i'm wondering if the numbers are just a display rather than a control.
and if both fuses are good it may just be a shorted display chip
it looks like it has a big switch so maybe it just has full power and half power (half wave rectified) to the heater
The big (0-1) switch is on/off. The temperature & timer go up to 9 I think via the soft-press gray buttons
here is a different repair on the same controller . https://jestineyong.com/homemaker-el...ow-rug-repair/
and here is a pic of how it looks on the front .
​Leave a comment:
OP said it was likely a short between mains and the thermistor, he binned it.Leave a comment:
by ZixuTechThis is a Data Recovery case from Lenovo Yoga 330 11IGM onboard eMMC Sandisk 128GB
Seems like the device had a power surge. Blown U6002 and went and cracked the die of the KBD controller. I detached the JP6003/4 tracks around U6002 but short still appears around the kbd controller (i believe)
I havent had a case to replace and reprogram KBD controllers before. How can I get the dump and what tool do I need to use. Is there a process written somewhere? Thanks in advance.
Let me know if you know any jigs which can recognise these sandisk chips. I wont mind...4 Photos01-01-2024, 10:15 PM -
by reessiHello,
My friend asked me to replace the wire going from this SMPS 20v adapter to the charger for a 18v Lithium Battery for a drill.
The cable had frayed and been touching, as a result the 5 Paralleled R200 (0.2 ohm) resistors had blown O/C, they are connecting the main -ve rail to the output wire.
The output was jumping around 13v and dis-appeared when a load like the charger was connected, they measured 900ohms.
I experimented by replacing at first a single 0 ohm and then a 2.2ohm in and the output was restored at 21.62v and 21.65v respectively... -
by master3112I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on... -
by TinkerTronHey everyone,
I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
Instead, here's what's been bugging me so far:
The schematic...3 Photos-
by redbaron1007I got a High Power HP1-J600GD-F12S on the bench today that was killed by roaches judging by the dead roaches and large brown spots in the housing next to said roaches.
I was able to identify all the blown smd resistors on the board aside from the one located at R69. I wasn't able to figure out what any of the marking on the resistor was supposed to be and with how little of the marking was left I wasn't able to really make any guesses about what it could be from the surrounding components. It is connected to pin 1 of Q11 (4N65SFA1K) which looks like it is the gate .In the sample...6 Photos - Loading...
