Kitchen AId dishwasher unresponsive
  • magistertc
    • Feb 2006
    • 25
    Kitchen Aid Superba KUDS series, installed 2001, similar/identical to Whirlpool -- live, but no Start and no response to button-press.
    The reset sequence of pressing two buttons multiple times did not work, either. Cycled power, no go.
    Power off, remove six screws (torx 7 heads) examine circuit board: Saw two 63V/100uf caps, two more 10V caps, all appeared normal. Mutiple color-coded wires to board,
    got all disconnected, dismounted board from housing. ESR test showed that 63V caps had failed.
    Jamicon 105 C TK series, 8D x 12. Replaced both with equivalent 'nichicon' PW(M) series, reassembled everything, power ON, works!
    KUDOs to BadCaps for inspiring my thought to replace a couple 20-year-old capacitors.
    Tom C
    Starts
    04-17-2024
    Ends
    04-17-2024
    Location
    Kansas USA
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8190
    Had a Bosch dryer that wouldn’t react to button press. It was the tactile. But you did a solid fix!
    • Kemer
      Liquid flux in kitchen owen
      by Kemer
      I will heat a graphics card in kitchen owen and will use a little liquid flux on it. I probably won't use that small owen for cooking pupose but want to ask if someone tried the same thing. Thank you.
      10-20-2024, 03:05 PM
    • yavqq
      Sony XBR-65x900F troubleshooting unresponsive TV
      by yavqq
      This all started a few days ago when out of no where the TV appeared unresponsive. Pushing the power button did not do anything and there was no standby light active. However, holding the power and volume up button while plugging in the AC power did show a steady solid green light. Still no display and no further activity from there.
      After some research I did some measuring of the common voltage points..
      Main Board Connector
      Pin 02 "BL_ON": 0.00V
      Pin 03 "POWER_ON": 3.47V
      Pin 05 "STBY 3.3V":...
      02-09-2023, 10:14 AM
    • DemonBG
      Samsung QN82Q60R - locks up / Crashing / Unresponsive
      by DemonBG
      Picked this one up a few days ago. QN82Q60R. Screen works perfectly and sound works but after booting, the unit randomly becomes unresponsive to input (though whatever is on the screen will continue to play).
      Tried standard reset - no improvement.
      Tried service mode reset - No improvement
      Service menu is difficult to navigate as the unit regularly crashes / locks up which means i have to restart the set.
      Something i have also not seen before is that sometimes (not always) when i enter the service menu, i get an error "ERR by empty version Data....
      03-16-2024, 09:49 PM
    • RolandVossen
      Kenwood Chef KVC50 / KVL60 / KVC5000 / KVL6000 / KVL6030 / KVL6050 kitchen machine repair
      by RolandVossen
      I am attempting to repair a KVC50 kitchen machine. Problem is that speeds 1..5 on the speed dial do not work at all (motor is not engaged). The 'reverse' and 'slow' settings on the same dial however work properly. I removed the dial, its PCB components seems to be basic: a potentiometer, a microswitch, a couple of LEDs and a couple of SMD diodes or transistors. The dial has three cables with three connectors that hook up to the motor controller PCB. One connector (3 pins) for speed, one connector (5 pins) for the LEDs, and one connector (2 pins) for a safety switch that is...
      03-16-2024, 03:55 AM
    • I8jjrnhh4thvtl0dWZoY
      Repair Manual for Bosch SHX55M05UC/46 Dishwasher (702_58300000148618_ara_en_a)
      by I8jjrnhh4thvtl0dWZoY
      Repair manual part number 702_58300000148618_ara_en_a
      It took way too much effort to find this manual so I am sharing it here so the next person can find it easily. Also, I am mad at Bosch for not publishing it on their website, so they deserve to have it leaked....
      07-14-2025, 07:36 PM
