OK, At work (I'm a maintenance mechanic/technician), we have a 120v (USA) twist-lock receptacle that is 1. split into 2 separate circuits, and 2. Showing 120v between hot to neutral, and 12-v hot to Ground.0v N-G, so far so good. The motor that plugs into it does not work, but works elsewhere. There is not much of a circuit, just a breaker, on/off switch, fuse, outlet, and wiring ran maybe 10 feet or so.
And yes, I used my fluke clamp-on to check everything. Can someone explain why I have voltage but nothing runs when plugged in???
 Puzzling Electrical problem
