Puzzling Electrical problem
  • Shagreobe
    Confused Newbie
    • Oct 2022
    • 16
    OK, At work (I'm a maintenance mechanic/technician), we have a 120v (USA) twist-lock receptacle that is 1. split into 2 separate circuits, and 2. Showing 120v between hot to neutral, and 12-v hot to Ground.0v N-G, so far so good. The motor that plugs into it does not work, but works elsewhere. There is not much of a circuit, just a breaker, on/off switch, fuse, outlet, and wiring ran maybe 10 feet or so.
    And yes, I used my fluke clamp-on to check everything. Can someone explain why I have voltage but nothing runs when plugged in???
  • petehall347
    • Jan 2015
    • 4445
    neutral is at ground potential so would see 120v v ground to live not 12v
    like yours .
    anyway are you checking voltage with motor plugged in ?
    • redwire
      • Dec 2010
      • 3912
      It could be "ghost voltage"- whereby you read a good voltage but it's a lie. This happens with digital multimeters.
      It's caused by a bad connection that is corroded or wet. That looks good to the multimeter because it has high input impedance and does not draw appreciable current through the connection.
      I'd expect 120VAC L-N and L-GND, and a volt or so N-GND. I think OP 12V means 120V? The cord can be checked with some other load, like a light.
      You need the "LowZ" feature on a multimeter, this draws more current when taking voltage readings so they're not affected by dirt and water.
      Does your model of Fluke have this feature? It's essential for electricians and plant work.
      I got screwed over by this fixing a CNC machine,voltage readings at the fuseholders looked fine but the machine was dead, no power. Turns out, CNC coolant residue was everywhere and that was enough leakage current for my DMM to read OK.
      Old analog voltmeter showed it right away, no voltage after the fuses- the fuseholder springs had been squished and not making a connection. Cost me many hours.
      • Shagreobe
        Confused Newbie
        • Oct 2022
        • 16
        That should be 120v, missed a zero. We have put a plug with bare accessible wires/terminals in and measured
          • 31258
          read the voltage again - with the load connected.
          incase there is a loose connection upstream.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8340
            Only because your meter sez it sees 120vac there at the plug, doesn’t mean it can handle current! Plug in a light something halogen or incandescent that draws some current, even if your Fluke has the Low -Z function. Then measure the voltage across that light bulb.
            • Shagreobe
              Confused Newbie
              • Oct 2022
              • 16
              Found a loose neutral wire on the light part of the switch, that I guess was only making contact when I looked at it lol
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8340
                Just as figured… just glad you found and corrected the problem.
                  • Jul 2011
                  • 6070
                  Only because your meter sez it sees 120vac there at the plug, doesn't mean it can handle current! Plug in a light something halogen or incandescent that draws some current, even if your Fluke has the Low -Z function. Then measure the voltage across that light bulb.
                  I would second this idea as well
                  A loose neutral wire will give you headaches as well
                  Incandescent light do not lie if the filament is good when I am in doubt that is what I use if I get weird reading on a meter
                  You got to be careful when checking 24 volt control circuits with a incandescent light because if these circuits have a high current demand on them you will get a false positive that you might have a short circuit but in reality it just pulling more current than the glow of the light is misleading
                  Because this machine has all of the proximity switches all in the same 6 amp circuit plus a push button switch which is the wire that was pinched to the cover for the switch
                  I had this situation today on a folding machine it turned out to be a wire to a switch that got pinched in the switch cover and tripping a 6 amp breaker that is reset-able
                  I was able to get the machine back up and running again with out the switch wiring I will have to fix that tomorrow morning when I get there unless somebody else gets to it before I do
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8340
                    Nice find, Sam! I am using the light bulb as a load or limiter quite a bit. Works good. I had a non existing neutral situation at my son’s residence. Luckily I checked it before he used it.
                    • sew333
                      Apartment to buy with coal heating. Any sense to buy electrical heater and new pc?
                      by sew333
                      Hi guys. I have an question. Overall i am currently selling my house ( apartment with 1 room ) to buy some cheaper with 1 room too, and save cash for new pc in autumn 2024.
                      So i choosed some cheaper apartment in smaller city,but there is coal heating. I dont wanna heat for coal.
                      So i m thinking to buy electrical heater. And my question . Is this any sense to buy electrical heater when i will be using new pc with rtx 5090 and new intel ( when will be released ) ultra + Psu Seasonic 1600W?
                      I expect that i will pay more for bills. But i wanna know this. Will using electrical...
                      06-14-2024, 07:30 AM
                    • Asxetos21
                      Dell Latitude 5511 audible electrical noise
                      by Asxetos21
                      I have a Dell Latitude 5511 laptop, and lately, a faint but clearly audible electrical (crackling) noise comes from the motherboard, similar to the random clicking coming from a mechanical hdd's heads moving inside it.
                      The laptop shows no signs of malfunction, and clearly this is electrical not mechanical, so my suspicion goes to a dodgy component in the power rails (a capacitor or a coil?). I fear this could develop into a serious damage.
                      Any advise on how to narrow it down?
                      The schematic is available here:
                      Dell Latitude 5510 5511 - Precision 3551 FDV50 FDV51 LA-J282P...
                      03-03-2025, 09:53 AM
                    • Microeletronica
                      HP foxconn 115xdbp 86dr motherboard bios and electrical diagram
                      by Microeletronica
                      I need the electrical diagram and bios for the HP foxconn 115xdbp 86dr board, does anyone have it?
                      09-10-2025, 07:57 AM
                      Aquarius WaterPik WP-100W water flosser
                      by momaka
                      And for today's “Other Weird Devices” thread, let's have a look at an Aquarius WaterPik WP-100W water flosser. What is it? Apparently, it's kind of a power washer, of sorts, for cleaning teeth & gums. Who knew these existed, right?
                      A family friend asked me to take a look at their older one, since it stopped powering On. So let's have a look at what went wrong.
                      First, a view of the box (note: it's from a newer model) and the device itself:
                      ^ Is it me, or does anyone else find it a little humorous how the box says it's “ADA Accepted”? ...
                      09-29-2021, 09:26 PM
                    • schnauzer2021
                      Chasis bond to neutral to overcome oven tripping problem
                      by schnauzer2021
                      I have a 6 years old Rowenta table top oven. The oven have both convection and grill function.
                      Last Christmas I used it to roast a turkey with the convection mode for about 4 hours without any problem. When I switched to grill mode to deep browning the turkey for the final half hour, the power trips after a while.
                      I have not been using the oven since then. Last week, when I try to use the oven again, both convection and grill mode trip the power supply a few minutes after turning it on.
                      As I was too busy with my work, I leave it to the repairman...
                      09-13-2021, 02:40 AM
