Monitor Interlook switch on a microwave
  • papillon
    • Mar 2023
    • 17
    I *was* trying to determine the cause of a failure in a microwave oven.
    The unit is a Frigidaire Gallery model CGMV175QFA.
    For future reference, the exploded view for this specific model is available here.
    The last page of that document also has the electrical diagram which I am attaching to this message as well.
    The unit had a blown fuse when I opened it. I tested each component individually (magnetron, relays, tracsformers, etc) and all appeared to be working fine (no shorts) but the fuse kept blowing.
    Eventually, I looked at the electrical diagram (attached) and noticed that the circuit has a Monitor Interlook switch (on the right side of the diagram), which, if closed would short the 120v power line. That was exactly the symptom I was seeing and since everything else was in working order, I removed the switch and tested it. Low and behold, it powered up, lit the light when the door was opened, and even the magnetron is working fine! It was fixed!
    So the interlook switch must have been defective, but since this is my first time digging this deep in a microwave, I'm curious: what does a Monitor Interlook Switch do, really? The electrical diagram is clear: it shorts the power line when closed. So other than a fuse blower, what is it supposed to do? And can the microwave work fine without it? Would it be safe to do so?
    thanks for your insight
  • papillon
    • Mar 2023
    • 17
    Re: Monitor Interlook switch on a microwave
    A quick search reveals that "interlook" probably was a typo and should have read "interlock" instead. It could be that the role of that switch is to fail when a specific condition is detected. but is it good design to have it blow a fuse when that occurs? Is that how all microwave ovens are designed?
    And what exactly is it monitoring? An open door?
    I'm probably missing something pretty obvious, so thanks for shedding some light on this for me
    • diif
      • Feb 2014
      • 6978
      • England
      It stops the magnetron being on with the door open.
      https://appliantology.org/blogs/entr...icrowave-work/
      • papillon
        • Mar 2023
        • 17
        Thanks for the link: very informative article.
        A dead short by design!? That's an effective (and pretty radical) way to implement a safety measure!
        thanks again!
        • R_J
          • 9583
          If the monitor switch is bad, it is usually a good idea to replace the interlock switch as well, It's contacts likely stayed closed when the door was opened and the monitor switch did its job but remained shorted.
          • papillon
            • Mar 2023
            • 17
            There's still something I'm not understanding. On the diagram attached to the first post, the monitor is connected on the 'left' side of the power relay, while the transformer is on the right side. Shouldn't this mean that when the door is closed, the monitor is also closed, thus causing a short?
            If the monitor were on the other side of the relay, I would understand: if the door were opened while the transformer was active it should short, but having the monitor located before the relay does not work in my model, so obviously I'm missing something!
            In the blog article referenced above, the monitor is indeed located after the relay, and that makes sense, but that's apparently not how this unit was designed. To confirm, I disconnecting the PCB assembly completely, and indeed, simply closing the door causes a short. This behaves exactly like what the diagram says, but doesn't make much sense... So again, I'm missing something!
            • petehall347
              • Jan 2015
              • 4435
              • United Kingdom
              if everything is working correctly, the monitor switch should never be closed at the same time as the interlock switches. In fact, the only situation in which it would be possible for the monitor switch to be closed at the same time as the door switches is if there's been a mechanical failure of the door latch/switches.
              • R_J
                • 9583
                Like petehall347 explained above
                When the door is open, the primary interlock switch is OPEN and the monitor switch is CLOSED. When the door closes, first the monitor switch opens, and then the interlock switch closes. This is all to prevent the door being opened while the magnetron would be on. Having the monitor switch before the relay is the best way to do it.
                • papillon
                  • Mar 2023
                  • 17
                  Finally had an opportunity to go back and look at the switch. What I found leaves little doubt as to the cause of the failure!
                  Thanks for help me understand how microwaves are designed!
                  • gabri2211
                    I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
                    by gabri2211
                    hello everyone, I'm looking for the wiring diagram of this led monitor.
                    the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
                    I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
                    I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
                    thanks to those who will answer
                    12-10-2024, 04:37 PM
                    by momaka
                    03-15-2023, 10:17 PM
                    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-06-2024, 05:30 AM
                  • jm1234
                    microwave rotary switch contacts go bad requently
                    by jm1234
                    Hi, I have a 11 year old microwave Siemens and the main function selector switch is a rotary type. It goes bad every few months, there are carbon (?) pads and the metal contacts that drive on them create concentric circle tracks from the residue.
                    I clean the tracks and the metal contacts with IPA and it works few months again. Here you can see the contacts:
                    Once I tried this contact cleaner: Kontakt 60 https://www.tme.eu/Document/3f58feb2...TAKT60.DTE.PDF, but it only lasted few weeks, so probably not a good choice.
                    Is there any...
                    05-04-2025, 10:45 AM
                  • ArchangelGabriel
                    Aorus 17G YD laptop, broken display, could not switch to external monitor
                    by ArchangelGabriel
                    Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
                    11-23-2023, 03:55 AM
