Likorall 200 Ceiling Hoist - Lithium battery conversion
  • Likorall 200 Ceiling Hoist - Lithium battery conversion
    I am considering a Lithium battery conversion for our Likorall 200 Ceiling Hoist as it is about at the end of its current set of batteries but I was wondering if there are any considerations I need to think about such as voltage regulation.
    It is used for powered transfers of a disabled person from chair to bed a few times a day in a private household. It is our own property and is 6 years old.
    It is fitted with a pair of Yuasa 12V 2.4Ah AGM batteries in series for a 24V system. The batteries are the long thin type with the terminals on one end connected via 4.8mm spade connectors.
    The charger in the UK 3-pin socket is a Pb battery charger rated at 100-240V, 50-60Hz AC outputting 24V DC at up to 0.5A with model number FW7218M/24. It ends in a standard 5525 barrel jack.
    The free-floating hoist has a handset with two buttons and an LED indicator on a curly cable that docks in a cradle. When the handset is docked the hoist is electronically prevented from operating while the batteries are on charge.
    The Pb charger has an LED indicator showing charging/charged. The handset has a bright yellow LED to show it is connected to the charger.
    It spends almost all of its time connected to the charger for battery management so any Li cells would have to be of a type that tolerate being fully charged very well.
    When the handset is removed from the charger the indicator LED dims and goes green to presumably show "good charge". It will either change to yellow or start blinking to indicate "low charge" but we have never used the hoist that much in one day to trigger that condition.
    I suspect that if I was to change the wall charger to one which supported Lithium cells (that could be connected to the charger long term) and replace the pair of Yuasa cells with a single Lithium pack of around 24V with the appropriate connectors we would be good to go apart from voltage regulation.
    Would I need to consider the voltage range of a 24V Pb sytem between 100% down to about 50% and make sure the Lithium pack was operating at the same sort of voltage? I have not examined the ceiling hoist to see if there is any regulation circuit on its main board yet but I could certainly do so.
    Before I start drawing up a shopping list, what else should I be thinking about? So far I know I need a Lithium charger and a suitable battery around 24V, probably LiFePO4.
    Thank you.
  • motormayhem
    Lenovo T460 Only Charges on One Charger
    by motormayhem
    Laptop Question
    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
    05-12-2023, 01:46 PM
    NVDC charger configuration...
    11-05-2024, 03:28 PM
  • flat-earther
    ASUS X54H laptop thinks it's always charging even with charger unplugged
    by flat-earther
    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
    Windows also shows ''Plugged in'' when charger is not connected.
    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
    If I let battery run out and say it has 3% Windows will...
    06-24-2025, 09:32 AM
  • Johndill
    Dell Inspiron 7567 LA-D993P odd charger issue
    by Johndill
    Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
    There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
    I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
    Here are the tested scenarios:
    1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
    2. With the laptop off, plug in charger (LED says on) & the front charging...
    11-16-2022, 10:55 PM
    ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
    Highly Integrated Narrow VDC Battery Charger for Notebook Computers
    The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
    for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
    Narrow VDC applications where the system power source is
    either the battery pack or the regulated output of the charger.
    This makes the max voltage to the system equal to the max
    battery voltage instead of the max adapter voltage. Operating
    at lower system voltage can improve...
    11-05-2024, 04:43 PM
