Please help for schematic for this PCB DA41-00757A
  • Competty
    • Feb 2023
    • 10
    • Sweden
    Hi there,
    I'm stuck whit this board, trying to find the issue why the motor controller on the heat sink is blown up (I'm at the early stage of troubleshooting so go easy on me) the fuse blown up as well, the big cap needs to b replaced and some diodes/SMD resistors or probably more stuff.
    PCBs ID is DA41-00757A and its mounted on a Samsung Freezer Model:RZ90FABB
    I'm following a Youtuber about troubleshooting PCB and find out some of the parts value is incorrect so i need to order new parts.
    Which website is best match to order parts for PCB in Europe and please some one help me for schematic for this. Btw the freezer is 11 years old.
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: Please help for schematic for this PCB
    This video , although in Arabic , is subtitled concerning the main parts and their functions in this PCB . For example , I knew the inverter IC part name as subtitled on screen and it's SLA6805M , as well as the other important parts like the TOP245P , etc .. So it's very useful .
    https://www.youtube.com/watch?v=YakUBkPyhV8
    • jiroy
      • Jun 2016
      • 2416
      • Lebanon
      Here's another same case one , explaining that the TOP245P is mostly always the trouble maker in this PCB .
      https://www.youtube.com/watch?v=mD-SDC4WuDk
        • 31044
        then i will add something i'v said in other threads.
        whenever you get a dead TOPSWITCH device,
        replace the startup capacitor - because it can kill the chip
        • jiroy
          • Jun 2016
          • 2416
          • Lebanon
          Definitely true , stj;
          • Competty
            • Feb 2023
            • 10
            • Sweden
            Thx for the replay, i ordered SLA6805M and TOP245P/startup cap and lucky me wiring schematic as well i uploading it in case some poor fellow ends up in same matters.
            I will update soon as i got the parts.
            Many thanks for all help.
            • lotas
              • Jan 2016
              • 4613
              • Russia
              If your compressor driver exploded, then it is likely that the micom UPD78F1201 (with locked firmware) suffered, and this is already a disaster, only the replacement of the entire board.
              • Competty
                • Feb 2023
                • 10
                • Sweden
                you just killed that joy i had a moment ago, all R505-516 shows 200kohm (300kohm is the correct value) and R502 is blown away, ZD501 shows 0.121v and RK49 diode at 0.161v.
                So is this dead or should i putt some effort on it and give it a try? or do you mean the main board as well?
                • lotas
                  • Jan 2016
                  • 4613
                  • Russia
                  You are not measuring something, you need to measure the resistance of the pins on the micom (microcontroller) relative to gnd, if these pins have low resistance or a short circuit, then only a replacement, then how lucky. And it's better to remove this exploded driver so that it gives an error in the measurement. Or power on, apply 5v to the controller and check if it heats up quickly.
                  • Competty
                    • Feb 2023
                    • 10
                    • Sweden
                    I did a measurement on the pins you marked to GND and no resistance on any marked pins. Gonna remove the driver and do it again. Do i need to replace SMD resistor when they show 200K instead of 300kohm regarding the schematic?
                    I don't have a PSU, gonna order it today.
                    • lotas
                      • Jan 2016
                      • 4613
                      • Russia
                      Remove the chip first and then measure everything again.
                      • Competty
                        • Feb 2023
                        • 10
                        • Sweden
                        No short whiteout the driver ether.
                        • Competty
                          • Feb 2023
                          • 10
                          • Sweden
                          Re: Please help for schematic for this PCB DA41-00757A
                          I change the parts and powered up the pcb, some reason i got 320v in the red marked area almost everyware on the board except REG1 area
                          Following parts is replaced:
                          C102
                          TOP245PN
                          D103
                          Reg2 AND Reg3
                          SLA680MP
                          Any idea whats going on?
                          • lotas
                            • Jan 2016
                            • 4613
                            • Russia
                            There is a different GND (-), on the hot side and on the cold side, and they are not connected, be careful.
                            • Competty
                              • Feb 2023
                              • 10
                              • Sweden
                              Ok i got it but i dont have 15V or 5v on Reg2 or Reg3 or Reg1
                              • lotas
                                • Jan 2016
                                • 4613
                                • Russia
                                Well, there are two options, either they overlooked something and something else burned out with PWM (resistors, diodes, optocoupler, ...) or defective (substandard) PWM itself.
                                • Competty
                                  • Feb 2023
                                  • 10
                                  • Sweden
                                  Is it possible transformer is shorted? I desolded the transformer and messured all pins and get 0.1 ohm on the pins, i dont have any info on the transformer
                                  • lotas
                                    • Jan 2016
                                    • 4613
                                    • Russia
                                    The main thing here is that there should not be an interturn short circuit on the power winding between 4-5 there should be several Om.
                                    • Competty
                                      • Feb 2023
                                      • 10
                                      • Sweden
                                      Thx Lotas you found it, its only 0,8 Ohm so this is smoked. Now how to find the part? i trying to serch online for this transformer but no luck
                                      • Mark D
                                        Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                                        by Mark D
                                        The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                                        10-29-2024, 03:15 PM
                                      • atunguyd
                                        Acer x163w Monitor PSU schematic
                                        by atunguyd
                                        Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                        The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                        03-05-2025, 02:08 PM
                                      • H H
                                        3090 FE Part Confirm/Identification
                                        by H H
                                        I'm hoping someone could help me confirm if I have identified the following parts correctly.
                                        Apparently the DP cable became stuck inside the graphics card and was yanked out. This caused some sort of short which burned the DP contacts and blew some resistors and ferrite beads.
                                        The parts needing replacement are on the back of the board behind the HDMI input.
                                        I have identified the parts as the following:
                                        C6037: MLCC 0.1uf/16v(0402)x7R W05
                                        R6016: RES 499 OHM 1/16W (0402) 1%
                                        LB10911: Ferrite Bead (0402)...
                                        02-16-2025, 01:09 PM
                                      • Thetechdude
                                        MSI Ventus RTX 4080 16G Broadview schematic needed
                                        by Thetechdude
                                        Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                                        I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                                        Thanks.
                                        07-15-2025, 11:15 AM
                                      • Adv10119
                                        Need help please! schematic for LA-9982P rev 3.0 (A02)
                                        by Adv10119
                                        Please help, i need schematic diagram for Dell inspiron 3537 board LA-9982P rev 3.0 (A02). Specific for A02.
                                        I have a one beep with no display problem. Did reprogrammed the bios but no luck. i tried to troubleshoot using rev 3.0 (A08) version schematic and boardview but there's components/rails in the schematic that is none in my actual board, this is why I'm having problem checking every power rail needed if ok. attached is the photo of my actual board.
                                        I'm not sure if A02 and A08 is really different schematic version from each other, but I have to try....
                                        01-31-2024, 01:18 AM
