UTC7608D datasheet
  • camelpipe
    • Sep 2022
    • 17
    • United Kingdom
    UTC7608D datasheet
    hi guys
    any body help me find the data sheet for this please
    UTC7608D
  • lotas
    • Jan 2016
    • 4708
    • Russia
    Re: UTC7608D datasheet
    Its full analogue is the SDC606P with the letter "P"!
    • electomech-fixer
      First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
      by electomech-fixer
      I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
      I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
      Yesterday, 01:42 AM
    • SoulFreeze
      Help finding datasheet for component marked G34662
      by SoulFreeze
      Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
      Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
      Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
      05-01-2025, 03:56 AM
    • Rainbow_Chameleon
      Searching Datasheet for AM113 IC by O2MICRO
      by Rainbow_Chameleon
      I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
      Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
      If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
      On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
      So if anyone has a datasheet or at least...
      01-23-2025, 12:03 PM
    • tofik
      Igbt rjp63k2 smd vs tht
      by tofik
      Hello guys,
      I have a shorted IGBT transistor RJP63K2 TO220F (THT).
      Could I replace it with a RJP63K2 TO-263 (which is SMD)?
      Apart from less convenience of soldering this element, should it be working fine?
      I could not find a datasheet for RJP63K2 TO-263 but noticed that for different transistors, the Power Dissipation value is different for different types of the body (TO220F and TO-263 for example).
      07-19-2023, 05:43 AM
    • Lee M.
      LG 55LN5710 backlight diffuser sheet order
      by Lee M.
      Hello all, new member here. I replaced the LED strips and found that the BL can be turned on with the TCON board and LCD panel disconnected. So new LED strips are working fine. Now the problem. There are 3 diffuser sheets on this set. One sheet is thicker than the others and I know it goes in first next to the LED strips. But one side of this sheet has a rougher texture than the other side. Does the rough side go up or down? The 2 thinner sheets have tabs that will only allow them to be installed one way so that's good. One sheet is what I would call plain translucent. The other sheet is whiter...
      11-29-2021, 07:52 PM
