isolation transformer from two 240/12, wiring?
  • harp
    • Jun 2022
    • 616
    • Planet Earth
    When is talk about making isolation transformer on poor-man way, always I see schematic 240/12-12/240.
    So, I wonder, is this wiring from my attachment it work, bringing some good feature or it is bad idea and why?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: isolation transformer from two 240/12, wiring?
    should work as long as you get it hooked up correctly (polarity is important...) but be worried about dielectric strength and thus shock hazard from the transformer itself since the LV wiring is usually on the outside...
    The traditional way also double insulates so it may be better in that respect, but this way adds more resistance in the coil paths so more loss this way, so six one way, half dozen the other...
      • 31157
      keep them a few inches apart or the fields will interact and mess up the voltage.
      • harp
        • Jun 2022
        • 616
        • Planet Earth
        Thank you, I guess that only secondary side must have correct polarity, like to adding the voltage on output, or the primary also must match - how to do simplest check of this?
        • redwire
          • 3912
          Where does that autotransformer connection come from? What's the advantage? Usually it's two back-back transformers, sec-sec. like Fig. 3 taken from Elliott Sound Products
            • Jul 2011
            • 6057
            I second this this what I seen before not the other diagram that was posted earlier by Harp
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              I suspect the intent was to minimize stage loss since if you connect two transformers in sequence, you lose a bit in both transformers.
              However connecting it the way suggested does not eliminate one stage of loss because you lose in the additional resistance due to series connection of the windings (versus transformer sequence). So ultimately you're probably not gaining much but losing insulation strength, hence my initial comment... and now have to say the traditional sequenced transformers is ultimately better at being an isolation transformer.
              • redwire
                • 3912
                I have a couple identical 120V-25.2VAC 2A Radio Shack 273-81512 transformers and just built both circuits, using a 40W load.
                The usual back-back connection works fine but the sag under load is 21%. So 120.5VAC in, 24.66VAC middle, and 94.7VAC out into 432mA load. No load was 118.7VAC out, 27.3V middle.
                OP's mysterious autotransformer sort of connection, does not work.
                Why? What happens is almost all of the incoming mains voltage is dropped across the 120-25V winding. Because the current in the 25-120V transformer winding is almost 5x greater, it's never going to get the current it needs to output say 100VAC. I got 25-35VAC total output phased right, load or not.
                Said another way, OP's circuit wrongly assumes things work with equal mains current flowing through the 120V and a 25V winding.
                I think it doesn't work at no load because the magnetizing currents are also 5X higher in the 25V winding.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Ah thanks for trying it, yeah more current needs to flow through the primary side low voltage winding but is limited by the high voltage winding. Perhaps with ideal transformers this theoretically should work but breaks down rapidly when there's losses and real current that needs to flow through real wire. (or perhaps they need to be magnetically coupled!)
                  Good thought provoking question.
                    • 31157
                    check arcade suppliers like WICO and HAPP.
                    older CRT based games use an iso transformer to drive the monitor for public liability reasons.
                    in europe it wont work because the transformers are 220 input and 120 output.
                    • ohren
                      Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                      by ohren
                      Hello!
                      I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                      Measured voltages with no load:
                      After rectifier diodes
                      12V: 6.17 V
                      5V: 5.67 V
                      Secondary transformer pins AC measurement (really don't know if this says anything)
                      12V: 2-2.5 V
                      5V: 1.04 V
                      I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                      03-18-2023, 10:33 AM
                    • mikey5791
                      Is it possible for transformer substitution?
                      by mikey5791
                      Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                      Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                      My questions are
                      1. How do i test to see if the transformer is in good working condition?
                      2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                      Hope you guys understand what i was asking. My intention is...
                      11-03-2022, 02:11 AM
                    • dennis_elx33
                      3PHASE STEP-DOWN Transformer in Check
                      by dennis_elx33
                      Hello All,
                      i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                      Problem statement: Power tripped Off
                      Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                      Action Done:
                      1) Replaced the faulty parts with good spare.
                      2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                      12-02-2024, 06:52 AM
                      ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                      This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 04:40 PM
                      ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                      This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 12:00 PM
