renesas IBGT alternative
  • luca120
    • Nov 2022
    • Lombardy
    some days ago my induction hob have decided to die , finally I found which component result damanged, before buy a new one to be honest I prefer to check if exist an alternative component this why isn't very cheap and here i italy isn't commecialized.
    the orginal component is: rensans mofest RJH60T4
    I checked this one FGH40N60SMD, but I don't know if could be good or not, some one could help me to find a good alternative?
    thanks to all
    Luca
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8344
    Re: renesas IBGT alternative
    EBay or AliExpress are sometimes your friend. Before you put the new IGBT in, check the gate drive circuit. Make sure everything is 100% ok, other than that, the IGBT will fail again.
      Renesas H8S/2112 R4F2112 R4F2112R - 16-Bit Single-Chip Microcomputer Datasheet
      H8S Family / H8S/2100 Series
      Ordering codes:
      F2112TE25V F2112BG25V F2112LP25V
      The core of each product in the H8S/2112 Group of CISC (complex instruction set computer) microcomputers is an H8S/2000 CPU, which has an internal 16-bit architecture. The H8S/2000
      CPU provides upward-compatibility with the CPUs of other Renesas Technology-original microcomputers: H8/300, H8/300H, and H8S.
      As peripheral functions, each LSI of the group includes a serial communication...
      10-23-2024, 02:33 AM
    • supravit2000
      PS4 slim SAD-001 board - how to tell the Renesas ic is bad?
      by supravit2000
      Hi, folks! I am not pro, just watch videos and try to find the error - sometimes it works.
      So I have been sold a ps4 with no hdd which should only be replaced. The machine boots up to safe mode and after assembling a new ssd, the update process returns an error su-42118-6 (sometimes SU-41333-4) which after some research, I found out that the console is for the bin as the renesas ic must be bad. The bd drive indeed shows no signs of working order (the button for eject still beeps, though, but a cd is not accepted at all). All the fuses on the board are fine, so are the caps/resistors....
      10-03-2023, 02:54 PM
    • baxmax
      alternative diode to Samsung TV 55 mb
      by baxmax
      Hi, Recently my Samsung 4K QE55Q60AAUXXH just suddenly stopped working_ there is no any sign of life - no red light or anything..and think, after diagnostic, it is diode DM863c SF28e PK33 siyu or one of these four. Is there any alternative I can replace with since it is hard to find it in my country and to order outside is quite difficult. thank you...
      10-21-2024, 07:35 AM
    • Norrecito
      iPod nano G3 - alternative soldering point for the white battery wire
      by Norrecito
      A friend of mine gave me an iPod nano G3 to see if I can fix it for him.
      The device had a faulty battery and he tried to replace it but failed. In the process he managed to pull off the pads that corresponds to the white battery wire (marked with a red circle in the images)....from both sides of the PCB. Fortunetely he didn't damage anything else.
      This is usually an easy fix HOWEVER, on the PCB, I see no traces coming from the VIA and after searching the internet, I've found no schematics nor boardview for this device. With the pads gone from both sides I seem...
      09-07-2024, 03:54 AM
    • Ado02
      ZB08P03 Alternative?
      by Ado02
      I am trying to source the ZB08P03 mosfet but can't find one in the UK. Can anyone suggest an alternative?
      09-25-2023, 08:42 AM
