Any way to identify a failed (simple/cheap) thermistor?
  • ja1870
    • Jul 2014
    • 16
    Just presuming it is a thermistor, and NTC, as when contacts are jumped (so zero resistance), the currently *not-moving* 12V case fan revs up to full speed.
    By eye (FWIW) about 1.75mm x 2.5mm, and no writing noticed.
    This is from an external 3.5" disk drive enclosure with a cooling fan, and the "thermal probe" - as it was called in the original installation manual - is held against the top-side of the HDD near the spindle.
    Hoping to simply replace it with a close-enough component.
    Thanks.
    Edit: after some further random visual-type web-searches, more definitely looks like it is a "bead-type" thermistor
  • redwire
    • 3910
    Re: Any way to identify a failed (simple/cheap) thermistor?
    Looks similar to a Japan-made, older Semitec part.
    Blue body and white marking would be a 103AT-2 10kΩ@25°C, B=3435K, see Radio Shack 271-110.
    You can also use a potentiometer in place of the thermistor to get a ballpark on its 25°C resistance.
    • ja1870
      • Jul 2014
      • 16
      Much appreciate the response. Very interesting thought re: the potentiometer.
      (Was actually wondering whether the white tip was OEM marking or perhaps some sort of failure indication.)
      • redwire
        • 3910
        These thermistors rarely fail, it's mechanical failure like a crack or tear from bent leads that ruins them. You can measure the one you have with an ohmmeter and see if it is working and the wiring is good.
        It might be that the temp sensor works fine but it's the fan circuit that is lazy upping the speed. They are usually not great designs.
        Is that text writing on the edge, looks like 504 or something?
        These are penny parts and the only one with a blue body and white mark is Semitec 10k.
        • ja1870
          • Jul 2014
          • 16
          Certain it is the Semitec as you suggested. Already ordered.
          No writing, so probably jpeg compression artifacts. And infinite resistance on the thermistor.
          Don't laugh too hard because I'm no pro...but went to the basement to extract a dusty old 150-in-One RadioShack Electronics Project Kit. Used a DMM to note the resistances at the potentiometer number-marks; wired it in, and found the fan went on at 5-6 kΩ.
          According to the spec sheet for the Semitec 103AT, that corresponds to between 40° and 45°C which make sense in this context.
          Do still prefer this 15-year-old enclosure because of the additional features and connections, but suspect the design was more for overheat protection rather than precise temperature regulation. By ear, the fan was pretty much either on or off. And the case already has a heat-sink which attaches to the HDD.
          • ahmedtou
            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
            by ahmedtou
            help me please
            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
            I will share all the details with you, including the disc information.
            Code:
            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
            Current Profile: BD-R
            Disc Information:
            Status: Empty
            State of Last Session: Empty
            Erasable: No
            Free Sectors: 12,219,392
            Free Space: 25,025,314,816 bytes
            Free Time: 2715:27:17 (MM:SS:FF)
            Next
            08-27-2025, 08:49 AM
          • nmbb
            Can not find Model/Value of Thermistor.
            by nmbb
            Machine: Autoclave.
            Brand/Model: SANYO MLS-3780
            Manual: (Sorry search option not working on this PDF)
            Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
            06-02-2022, 05:55 PM
          • digitalDNA
            Failed to identify SMD component with markings 81 and 947 and package SOT-89
            by digitalDNA
            I can't identify a component labeled Q1 on the main board of a redundant server PSU from Etasis, product name EFRP-465
            ICs on the board have labels with prefixes U, so we have U1, U2, etc. The mysterious component is labeled Q1, so it must be a transistor (BJT)/MOSFET/etc.
            I have attached the image for Q1.
            I have searched multiple SMD reference websites without being able to identify the component.
            Here is some important information from the board::
            1. Pin 2 and the tab are connected to GND (after unsoldering Q1,...
            10-07-2022, 04:47 PM
          • deltacomet
            Sharp aquos lc-80le757u thermistor identify
            by deltacomet
            I got a Sharp aquos lc-80le757u power board problem.
            Old owner change the thermistor by another part ??? and didn't work
            I repair all other problem, but I need this part for finish this board ( part ntc7001 )
            Can someone have a shematic or list part of the board.
            dps-299ap //RUNTKB159WJQZ
            Pic in the attachment
            Thanks a lot...
            03-20-2021, 03:36 PM
          • thesame
            DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
            by thesame
            Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
            The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
            02-27-2024, 04:31 AM
