Help identify varistor
  • otoluk
    • Feb 2009
    • 84
    • Latvia
    Need help identifying component.
    It has markings 07 431 VDE
    • 31015
    Re: Help identify varistor
    probably a 430v VDR - is it 7mm diameter?
    • otoluk
      • Feb 2009
      • 84
      • Latvia
      around 7mm yes
      looking for replacement.
      I have SCK 053 as spare or it is not VDR.
      • lotas
        • Jan 2016
        • 4596
        • Russia
        Originally posted by otoluk
        around 7mm yes
        SCK-053 is a thermistor (these are completely different components).
        http://www.datasheetcafe.com/sck-053...et-thermistor/
        • otoluk
          • Feb 2009
          • 84
          • Latvia
          So this is not inrush current limiter?
          How to verify if it is not bad?
          • lotas
            • Jan 2016
            • 4596
            • Russia
            VDR is a varistor (has no resistance) placed in parallel with the power supply (AC or DC)
            SCK is a thermistor (has a resistance) placed in the gap (as a current limiter) of the power supply.
            • otoluk
              • Feb 2009
              • 84
              • Latvia
              Double checked yes it is parallel to AC.
              • lotas
                • Jan 2016
                • 4596
                • Russia
                So what's the problem, it (VDR) usually explodes if the voltage has passed more than its nominal value.
                • otoluk
                  • Feb 2009
                  • 84
                  • Latvia
                  Seems it is not the problem. I got voltage drop on input so the converter shuts off after some 5 minutes looking for cause.
                  • otoluk
                    • Feb 2009
                    • 84
                    • Latvia
                    This is fuse?
                    C250 080 030W
                    measured resistance 19k Ohm
                    • lotas
                      • Jan 2016
                      • 4596
                      • Russia
                      A fuse cannot have a resistance of 19 kOhm. What is the position number on the board (designation)? And on the other side there is no inscription?
                      • otoluk
                        • Feb 2009
                        • 84
                        • Latvia
                        This seems to be resettable fuse - https://en.wikipedia.org/wiki/Resettable_fuse
                        Position number on board F6 and other side is blank.
                        • lotas
                          • Jan 2016
                          • 4596
                          • Russia
                          Well, if F, then yes it's a fuse, but it's strange that he's so pot-bellied. At 250v 800mA?
                          • otoluk
                            • Feb 2009
                            • 84
                            • Latvia
                            It is from Galmet wood pellet boiler controller.
                            Apparently it was left switched on all summer in tripped state. When it trips the LED backlight is not visible so looks switched off. Wood pellet boilers this year are very popular in our region.
                            • lotas
                              • Jan 2016
                              • 4596
                              • Russia
                              Well, then you need to replace it, put the usual one on 1A, to check the block
                              • otoluk
                                • Feb 2009
                                • 84
                                • Latvia
                                Isn't it 0.08A?
                                • lotas
                                  • Jan 2016
                                  • 4596
                                  • Russia
                                  I can’t say for sure (I need a datasheet) somewhere they write 080 - 80mA, but somewhere it’s 800mA.
                                  But 0.08A is some very small current for this block.
                                  • otoluk
                                    • Feb 2009
                                    • 84
                                    • Latvia
                                    Found manufacturer with similar symbol - https://www.made-in-china.com/showro...able-Fuse.html
                                    • redwire
                                      • 3910
                                      It seems to be 250V 80mA hold, 160mA trip PTC fuse, 6.5mm dia. Sea & Land Electronic corp. C250-080
                                      There is something else shorted for this PTC fuse to heat up and die. I would look for a problem in the power supply section.
                                      • otoluk
                                        • Feb 2009
                                        • 84
                                        • Latvia
                                        Thanks.
                                        The previous converter failed so maybe took this on the way.
