Transistor substition
  • madan1
    • Nov 2016
    • 682
    Hi everybody. Can anyone suggest a more widely available substitute for SVD3205T?
    It is used in a power inverter and 8 out 12 are gonesky, so basically I can purchase 8 from the usual place (aliX) and wait for a couple of months to arrive or just change all 12 with something that I can easily get in the local electronics shop.
    Thanks in advance.
    p.s. sorry for the typo in the topic label
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Transistor substition
    Thanks in advance.
    My suggestion is the write to the Company that makes the IC and tell them the problem you are having getting their product. This is their contact link.
    https://www.vbsemi.com/index.php?catid=45
    Most of this stuff is now made in Asia. This chip headquarters is in Tiawan, and I believe they just had a recent natural disaster in the Country. I will continue to look for a local company in Europe for you.
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      I could not find a simple cross reference to this particular manufacturer.
      You might want to contact support for Texas Instruments to help you find an equivalent.
      This is their support contact page one can email, chat or call them.
      https://ticsc.service-now.com/csm/?_...VjdCBPYmplY3Rd
      • lotas
        • Jan 2016
        • 4644
        • Russia
        Svd3205t = irf3205pbf
        • madan1
          • Nov 2016
          • 682
          Thanks for the replies!
          I don't think I will be contacting TI or SVD, the issues is not that the mosfets can not be purchased, but that the shipping time is month+. In aliexpress and ebay there are lot's of offers, but everything is from China.
          Local store has irf3205Z in stock, which according to the manual is same as irf3205pbf, so I guess this is what I'm getting tomorrow.
          Really appreciate the help!
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            The manufacturing companies have a lot more power in getting their product to market then their distributors. If the manufacturer is not getting feedback from the customer that needs the product, then they will never know.
            The reason why I said contact IT is because IT may be able to help you look up one of their products that is compatible to the SVD product. IT Products you may be able to get quicker. Many of the Mosfet manufacturers do not have a cross reference with the SVD product. I check about 3 main manufacturers including IT. However, that does not mean they do not have a product that meets all specification of the Mosfet.
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              Here is catalog distributors for Infineon irf3205
              https://www.infineon.com/cms/en/abou...tribution.html
              Here is all distributor for Infineon for EMEA countries.
              https://www.infineon.com/cms/en/prod...Id=140385#emea
              Perhaps you can get it cheaper at the one of the above distributors then down the local supply shop.
              The more you open up the available market the better chance of getting a product at a reasonable cost.
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                Thanks, lotas for the help.
                • magneh
                  Behringer Eurolive B205D repair - help identifying transistor
                  by magneh
                  Hello
                  Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                  Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                  After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                  I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                  Still, I need to replace this transistor....
                  06-18-2025, 02:34 AM
                • elsomer
                  help to identify transistor msi ms-15ck1
                  by elsomer
                  hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
                  02-17-2025, 05:30 PM
                • rddube
                  Help with blowing transistor NAD T752 receiver
                  by rddube
                  I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
                  Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
                  I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
                  09-01-2022, 05:19 AM
                • amigo744
                  xbox series x u82 5 pin transistor voltages ?
                  by amigo744
                  hello there,
                  xbox series x hdmi u82 transistor 5 pin,
                  can anybody tell me voltages of this transistor in standby and power on mode ???
                  on which pin of this transistor are the voltages ?
                  regards
                  08-16-2023, 08:05 AM
                  AO4601 AO4601L Transistor (Applications Laptops) Datasheet
                  Complementary Enhancement Mode Field Effect Transistor
                  The AO4601 and AO4601L use advanced trench technology MOSFETs to provide excellent RDS(ON) and low gate charge. The complementary MOSFETs may be used to form a level shifted high side switch, and for a host of other applications. Standard Product AO4601 is Pb-free (meets ROHS & Sony 259 specifications). AO4601L is a Green Product ordering option. AO4601 and AO4601L...
                  11-05-2024, 08:21 AM
