DIY Fan temperature control
  • c_hegge
    • Sep 2009
    • 5219
    I get sick of having all the fans in a PC running a maximum speed all the time because the motherboard doesn't support temperature controlling, but the PC gets too hot if you run them on 5v. The solution: This. I've put a few of these together so far and they're exclellent. Well worth the $5 they cost me to make. The other awesome thing is that i can choose the target temperature.
    Fintek F71868A Super I/O and Hardware Monitor Datasheet
    The F71868A which is the featured IO chip for PC system is equipped with one IEEE 1284
    Parallel Port, two UART Ports, one 80 port (multi with COM2), Hardware Keyboard Controller, and SIR. The F71868A integrates with hardware monitor, 9 sets of voltage sensor, 3 sets of creative auto-controlling fans and 3 temperature sensor pins for the accurate dual current type temperature measurement for CPU thermal diode or external transistors 2N3906. Others, the F71868A supports newest AMD TSI and Intel PECI 3.0 interfaces and INTEL Ibex...
    10-23-2024, 02:26 AM
  • CapLeaker
    AcuRite 5 in 1 temperature sensor replacement repair
    by CapLeaker
    Got a new victim:
    AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
    A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
    B: stuck at some temperature and maybe updating once in 12 hrs or so.
    Easy solution is to go to AcuRite website and purchase the sensor. Right?...
    04-15-2025, 01:32 PM
    Alexia thermostat is this a good idea for for controlling your air conditioning system feedback wanted
    My wife is asking me about getting one because our electric bill was that it has ever been even more than last year at this time nothing has really changed since last year last month unless the electric company has done some fuel adjustment charges I have not done any investigation into yet but I might have to but there was a time back a few years ago that I use to set the temperature warm during the day when we were not home but when we got wooden floors in our house and you have to keep the humidity down to keep it from warping I just set to a temperature to 75*F to keep the humidity down but...
    06-22-2025, 10:23 AM
  • capwizard
    Temperature control ?
    by capwizard
    is PID controller (a proportional integral–derivative controller) the best way to control the temperature? Example: BGA Workstation.
    Do I have another option for more accurate & fast response temperature controller? maybe Arduino micro controller with AI?
    over 90% of the controllers used today use some form of P-I-D control.
    PID control dates back to the 1890 meaning that a majority of the vehicles used today in industry are using a 126-year-old controller
    methodology.
    02-18-2019, 07:09 PM
  • Yanleb
    LG 60PK550 Logic Control Board EBR63450301
    by Yanleb
    Hi all, I just want to share the repair of my 60PK550-UA TV set.
    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
    C57: 3.30V
    C61:...
    07-20-2023, 12:38 AM
