Anyone know of an alternative for a R10E2662-2 DPDT relay
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    I'm having trouble finding an R10 E2662-2 telephone relay, originally made by Potter & Brumfield, and have also been unable to find a suitable replacement.
    It is missing from a Fluke 8600A bench multimeter
    It isn't really mentioned in the manual, yet judging by others in the series, it appears to have a 4.5v coil, but I could be wrong...
    I can find the later R10 E1Y2 relay, however it has a 12v coil
    Enclosing pictures of the socket and relay pin assembly
    Here is the service manual;
    https://cdn.badcaps-static.com/pdfs/...c6588cac76.pdf
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Anyone know of an alternative for a R10E2662-2 DPDT relay
    I can confirm it is most likely a 4.5v relay because it sits on the +5v line and is controlled by a transistor so that will have a 0.7v drop...
    • R_J
      • 9549
      Maybe this? R10-E2Y2-V52 (Digikey) 6v coil (operates at 4.5v) It has PCB terminals but might work?
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Looking at a photo here shows a coil resistance of 145Ω
        From that same series of relays you've shown we can see there exists a version with a coil resistance of 140Ω so pretty much a perfect match:
        R10-E1W2-S140 it is a 5v relay but it operates down to 3.75v
        Just need to make sure it has the proper number of contacts and the configuration they are in and that it fits the socket:
        https://eu.mouser.com/ProductDetail/...J6JE0CHQ%3D%3D
          • Jul 2011
          • 6040
          Even if the pins are not exactly the same if you have room in the enclosure you might be able to mount it some where near the board
          • CapLeaker
            Leaking Member
            • 8179
            As long as the coil voltage and relay configuration is the same, you can wire the new relay in and glue it in its new place. I even done this with unobtainable rf relays. Works fine as kind.
            • Crystaleyes
              • Sep 2021
              • 493
              • Brazil
              Fantastic info gents. Just what the doctor ordered.
              With so many different relay options, searching for an obsolete equivalent isn't so easy..
              Many thanks!
              • CuriousJohn
                Burco boiler power problem
                by CuriousJohn
                Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
                Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
                This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
                12-22-2024, 10:25 AM
              • jm1234
                9V relay temperature 40C
                by jm1234
                Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                05-09-2024, 03:03 AM
                Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                by sam_sam_sam
                I was working on this CNC machine today found no keyboard functioning no control relay powering on
                The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                Found shorted diodes on main controller relays there are 3 of them that...
                01-07-2023, 05:43 PM
              • edugimeno
                Repairing a ENERTRES Biomass BI-650 heater
                by edugimeno
                Hi all!
                A friend asked me to repair his biomass (pellet) heater. This heater has a pellet feeder powered by a relay that's not switching anymore
                I measured the voltage at the relay coil socket while entering the individual tests procedures and it has 6-7v while the relay is NOT on the socket, and drops to 0v when the relay is plugged in the socket, like the source is providing nearly 0 mA. I measured the relay coil and it is correct and not shorted so the issue is in the board, fed no amps to this output
                I checked the board at home and this output is driven by an...
                07-28-2025, 04:32 AM
                by momaka
                03-12-2025, 03:42 PM
