Can someone help me identify this SMD??
  • PeterPumpkin
    Peter Pumpkin
    • May 2010
    Would some kind soul out there help me identify this component?
    http://www.members.optusnet.com.au/b...images/smd.jpg
    From what i can make out, the values on it are "AE 84A G".
    It came out of a USB hard drive which had it's power input damaged and it must have shorted this component. From what i read this is a polarised capcitor but i'm not sure, and am totally confused by the values on it too.
    Thanks!!
    Last edited by PeterPumpkin; 05-26-2010, 06:16 AM. Reason: trying to change forum channel.
  • kikkoman
    • Jul 2007
    • 691
    Re: Can someone help me identify this SMD??
    I'm pretty sure this is a 1 or 2A Schottky diode.
    that logo points to General Semiconductor who were acquired by Vishay.
    i couldn't find a datasheet with these exact markings and Vishay has several '84A' schottkys ranging from 30V to 1000V and between 1 and 2A.
    it might be used as a reverse protection diode. in this case, i suggest you simply go with the higher current rating and the voltage depending on the circuit.
    you should be able to replace with any similar rated schottky.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • PeterPumpkin
      Peter Pumpkin
      • May 2010
      Thanks Kikkoman,
      I love this place! It's the first time I've heard the term Schottky. I even have trouble pronouncing it!!
      Just did a quick search on eBay for the component. Would it be better if i got a 1a 30v or a 1a 40v to replace it? Or is neither advisable??
      • kikkoman
        • Jul 2007
        • 691
        yea, you can learn lots of stuff here.
        basically, a schottky diode is a fast diode with low voltage drop.
        can you post a picture of the damaged board? it would help determining how exactly it is used and if other components could be fried.
        in case your HDD case has a 5V and/or 12V power supply (as most cases do) either voltage rating has enough reserve.
        you should definitely use a part with a higher current rating though (1A might even be too low for a 2.5" HDD).
          • 31278
          it's a "shot"-"key" diode.
          probably
          • PeterPumpkin
            Peter Pumpkin
            • May 2010
            Ok, this is the motherboard.
            The hard drive is a 3.5 inch one. You can see the burn marks near the bottom left of the pic. It was plugged into an external USB box. When it was found not to be working, we plugged it into another usb case, but it didn't power up. So i tried it on a 3rd usb case, and it cause one of the chips on the usb case to light up light a lamp! It was very pretty, but killed the case...
            I'm could also get 3a "shot keys" but am still unsure which i should use. I'm basically willing to give anything a gamble because the drive is dead as it is and if i make it worse, will just shop around ebay for a similar hardrive to get its mb. Just trying to retrieve data off the thing is all..
            Man, I've learnt there are 3 certainties in life. Death, taxes and problems with computers!!
            • boxy
              • Jun 2010
              • 5
              84A is a Vishay SS2PHx 2A Schottky rectifer. Unfortunately you can't tell what the reverse voltage rating is from this number, but a SS2PH5, 6, 9 or 10 will do here (multiply the number by 10 to get the voltage).
              Funny, I've got a reel of 3000 samples of them in a box in our lab. If you want to come up to the UK to pick some up feel free, but that drive is dead unless you caused a short with a screwdriver or something and are lucky.
              • briztech
                identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF
                by briztech
                Hi can anyone identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF - Thanks
                07-25-2024, 06:18 AM
              • rashidjafar
                Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
                by rashidjafar
                I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
                Values for :-
                PC43 : Capacitor [3x1.5mm]
                PL7 : Inductor [2x1mm]
                PC39 : Capacitor [1x0.5mm]
                Any ideas would be appreciated.
                I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
                08-07-2025, 05:10 PM
              • Kobok
                Different (lower) resistor values on PCB?
                by Kobok
                Dear Alls,
                For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
                09-19-2022, 07:30 AM
              • proxneo
                Recapping Sony ICF-SW55 - verifying cap values
                by proxneo
                Dear reader
                I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                At the moment, I have selected replacements based on the following list of values:
                3 x 470uF 10VDC
                3 x 4.7uF 35VDC
                4 x 47uF 50VDC
                8 x 22uF 6.3 VDC
                1 x 220uF 6.3VDC
                5 x 100uF 6.3VDC
                Which...
                06-21-2023, 12:38 AM
              • skdsp
                Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
                by skdsp
                I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
                Attached is the photo.
                Thank you!
                09-27-2025, 09:05 PM
