Query on 24V supply
+ More Options
Posts
  • jinu_j
    • Feb 2016
    • 90
    • India
    Query on 24V supply
    Hi Folks
    have a basic question on Fundamentals. I have a Power supply that has the following terminals +12V, 0V and -12V. Now normally i can get 12V by connecting between 0 and 12 and -12V by connecting load between 0 and -12V. I can also get 24V by connecting load between -12V and +12V.
    Now my queries
    1. Is the 24V i get by connecting load between -12V and +12V same as connecting the load between a 0V and 24V power supply. Is there anything to take care of when using one source against the other ?
    2. Now assuming there are 5A fuses between 0V and -12V and also between 0 and 12V. Now when i connect the load between -12V and 12V, would these fuses come into play?
    • 31055
    Re: Query on 24V supply
    is the + and - rated for the same current?
    • jinu_j
      • Feb 2016
      • 90
      • India
      Yes they are rated for the same current 5A
        • 31055
        then you can get 24v, but you cant connect the psu to anything earthed
        • jinu_j
          • Feb 2016
          • 90
          • India
          can i use this voltage/source on components that have specified range of 0-24V. For eg: if i am using an IC whose VCC pin range is 0-30V can i use this power source ?
            • 31055
            yes, but as i said - no part of your circuit can connect the 0v(GND) rail to mains ground.
            not unless you modify the psu first.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
              03-31-2024, 02:12 PM
            • Jembang
              coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
              by Jembang
              good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
              11-01-2024, 09:55 AM
              07-01-2024, 06:34 AM
            • shamsudeen
              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
              by shamsudeen
              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
              i know that in linear power supply the noise will be very low comparing to SMPS supply....
              07-19-2025, 07:14 AM
