Inductor or resistor
  • caprider
    • Jan 2022
    • 24
    See attachment.
    This blown component is connected to the output of a bridge rectifier on a SMPS.
    It looks like a resistor (it has colored marking lines), but it is marked as L1 on the PCB, suggesting it is a coil. Which is it?
    This is a very basic and cheap SMPS which I am analyzing for learning purposes.
    Thanks.
    PS: don’t worry, I know there are about 330V after that bridge rectifier IF powered and I take the necessary precautions.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8680
    Re: Inductor or resistor
    Still an inductor probably, they do make inductors like that but the ones that look like this are low inductance and low current handling...
    • caprider
      • Jan 2022
      • 24
      So they are both based on “How to diagnose and fix everything electronics” (attached). But what's their main purpose: coil or resistor?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8680
        Coil; probably half ^%%#* way of reducing EMI.
        • caprider
          • Jan 2022
          • 24
          And how many ohms does it have?
          I can’t decide if first and last colors are red/brown (maybe orange?).
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8680
            as low as possible...
            • redwire
              • Dec 2010
              • 3900
              The part is a ferrite-core inductor used for a differential-mode filter, roughly around 1-5mH. Purpose is to lessen the EMI and RFI noise from the SMPS primary that radiates out to mains. You could read the colour codes for its value.
              Cheapest chinese smps and wall-warts don't even have the inductor, they leave it out.
              Typically you would see a common-mode choke there but this wall adapter is low power 1.8W output and just a single inductor is used instead.
              The part must have got hit/broken somehow.
              • caprider
                • Jan 2022
                • 24
                Thanks. I didn't know coils have the inductance value color-coded.
                Based on lines it's 1mH.
                Can I replace it in this power supply with a coil of 1500uH, 100mA, 25Ω?
                • faraday28
                  • Jan 2022
                  • 15
                  • Indonesia
                  Basically Coil are inductor because they have inductance value.
                  Your power supply design is very weird, it usually use with real coil not low powered inductance such as the picture, it blown because it can't hold the heat from current passing through. that's typical cheap power supply, they use wrong parts (cheapest) for easily blown out and you will decide to buy another )
                  if you unsure, you can bypass it with jumper wire, because line filter (EMI filter) should be after line input. or you can try the 1.5mH, it doesn't do much.
                  Most cheapest power supply like this use the design without line filter or X cap or Ycap, because they tends to fail and blow up if they buy from cheapest distributor.
                  • redwire
                    • Dec 2010
                    • 3900
                    [...] Can I replace it in this power supply with a coil of 1500uH, 100mA, 25Ω?
                    That DC resistance is too high at 25Ω, and the current-rating 100mA is too low. You need something with lower resistance and higher current rating.
                    • Steph.hen
                      Bridge rectifier identification part number KPB305G
                      by Steph.hen
                      Hi all, a newby question about a bridge rectifier I'm trying to identify.
                      I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                      08-29-2024, 09:52 AM
                      KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                      by momaka
                      For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                      http://www.rmac.kingwin.com/products.../abt_650MM.asp
                      I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                      What mostly drew me into buying it is its 2x PCI-E power connectors...
                      03-29-2022, 11:34 PM
                    • mpn78
                      Fujitsu Q556, What capacitor for bridge rectifier?
                      by mpn78
                      Hello
                      My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
                      There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
                      Thanks....
                      04-05-2022, 12:31 PM
                    • madan1
                      Troubleshooting half-bridge smps
                      by madan1
                      Hello everyone, I'm trying to fix what seems to be a half-bridge smps.
                      The switching controller is sg2525a, which I have replaced with a brand new sg3525a. The low and high mosfets are 1c27ac 6n50. The mosfet driver is IRS2301S.
                      Both mosfets were tested outside circuit with a component tester and seem to be fine.
                      With oscilloscope I see ~65khz switching signal on both low and high outputs of the controller, but on the output of the mosfet driver there is switchig signal only on the low output (flat line on the high output).
                      So I guess the mosfet driver is faulty?
                      01-23-2025, 06:05 AM
                      Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                      by momaka
                      This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                      Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                      Macron Power Technology Co. LTD.
                      Let’s look at the PSU itself.
                      The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                      06-02-2021, 10:05 PM
