can a flyback transformer for USB charger isolate?
  • bohaboha
    • Nov 2012
    • 1017
    • sweden
    Re: can a flyback transformer for USB charger isolate?
    eccerr0r the tube led lamps should be out of function but the circuit itself is perfectly ok as myself i picked old led lamps from the environmental room that we have here where people throw what they do not need. sharing is for the idea that you asked to see
    then if you did not like ...
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Sorry, probably missed my rant about youtube videos... mainly because people still use machines that can't view them and it takes forever to figure out if it contains useful information 3/4 the way through or not...
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Originally posted by eccerr0r
        I'd like to see this switch mode transformer idea, it's possible but tricky to pull off...
        If it is what I think it is... I've done it, it's supper easy, and works 100%... but I've only had good success with ATX PSUs.
        Basically, take any old crappy ATX PSU (but preferably one that won't explode on you if you mistreat it ). Then find another crappy (preferably non-working) ATX PSU and extract the big/main transformer from it. Open the working ATX PSU and solder wires directly on the transformer's secondary side output pins (i.e. ground, 5V, and 12V... or 2x wires for 5V and 2x for 12V in case of half-bridge PSUs with a center-tap.) Place PSU back into its case, but bring out those wires outside for easy access/hook up (might help to label them first too, so you know what's what.) These wire outputs will now have low-voltage, high-frequency AC that you can use to drive just about any other SMPS transformer. Depending on how you connect these to the 2nd big/main transformer extracted from the non-working PSU, you should get back something like about 170V (or slightly more) high-frequency AC back on the primary-side pins.
        I suppose the same idea could/may (should?... to an extent) work with USB chargers too... but not sure how well. Main reason I think this might not be ideal is because most small USB chargers and other power adapters have "flyback" transformers that operate in discontinuous mode (i.e. secondary side output "pulse" occurs only after the primary side current is cut off, collapsing the magnetic field in the core of the transformer and releasing its energy on the secondary.) So if you hook up another flyback traffo "back-to-back" on the output of the USB/adapter, there's actually no telling if the output voltage on the "primary" of the 2nd transformer will be the same as that on the first... or consistent in any way. In fact, flyaback transformers aren't really "transformers" in the true sense. They are coupled inductors with a "gapped" core.
        So indeed that may be a little tricky with the USB chargers, as eccerr0r suggested... but certainly give it a try.
        On the other hand, with ATX PSUs, the main transformer operates in continuous mode, just like a regular line-frequency transformer does. So input and output voltages will be consistent based on turn ratios. Just have to watch out, though - the output of the 2nd (back-to-back) transformer is not protected in any way from over-power, over-current, or short-circuit... so you can fry your circuits easily if not careful. I suggest adding a 12V halogen bulb between the two low-voltage sides of the two transformers to limit power.
        Your rant is completely valid.
        If i had a penny for every self-proclaimed "tech's" video on YouTube, I'd be a millionaire myself. Seems like they are dime a dozen, and more popping up every day. A lot of them are just a waste of time, though... or too long to watch through... or too specific, as if the issue they found is the only issue you will ever find in such device.
        That's not to say there aren't any good tech/educational videos on YT. But the ratio of good/worthwhile ones to crap/garbage ones is very small.
          • Jul 2011
          • 6057
          Could you please post a picture of this circuit or a wiring diagram of how you would hook this up thanks
          • bohaboha
            • Nov 2012
            • 1017
            • sweden
            thank you momaka for your suggestion i was going to ask the same thing as sam_sam_sam if you could? and please can you say what you thought it was?
            • motormayhem
              Lenovo T460 Only Charges on One Charger
              by motormayhem
              Laptop Question
              I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
              A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
              05-12-2023, 01:46 PM
            • retrotechrestoration
              Looking for a flyback transformer for an Eizo TX-C7 MA-791 17" CRT
              by retrotechrestoration
              I just saved this magnificent RGB input Eizo Flexscan TX-C7 MA-791 from the local e-waste...good news, the tube works and the board looks great...the bad news, it sounds like the flyback is shorted. (Turns on...perfect picture...systemic high voltage crackling heard while the picture flickers...then it blows the 5A fuse in my isolated A/C power supply.)
              Anyone have any leads on possibly finding a replacement? (photo shows the flyback model numbers)​...
              03-22-2024, 06:50 AM
              NVDC charger configuration...
              11-05-2024, 03:28 PM
            • flat-earther
              how to prevent a connected charger from draining battery when not charging?
              by flat-earther
              I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
              So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
              but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
              So the battery is backfeeding the charger and being drained.
              How can I prevent...
              08-07-2025, 01:04 PM
            • flat-earther
              ASUS X54H laptop thinks it's always charging even with charger unplugged
              by flat-earther
              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
              Windows also shows ''Plugged in'' when charger is not connected.
              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
              If I let battery run out and say it has 3% Windows will...
              06-24-2025, 09:32 AM
