How big problem are insects for power supply?
  • LearningToRepair
    • Jul 2020
    • 35
    If power supply has ventilation holes from which insects can enter, and it is near the lamp - that means insects are attracted. How bad is it? I found that my ceiling light's built in power supply had a ton of insects inside and in this case it did not seem to cause problem. But how is it in general?
    For example one of the worst case scenarios would be
    Or a little bit better would be:
    Will they cause arcing with 230V AC?
    If it is known that it's gonna attract insects is IP67 the only option or are these kinds of power supplies fine also? Indoor use can be assumed. The source of insects is simply open window during summer months.
    Here is realistic expectation of insects:
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: How big problem are insects for power supply?
    that's a very buggy design...
    Mostly it's whether its ventilation is acceptable when bugs clog it up. The bugs will dry out and be insulative for electricity so that's ok but it will clog up airflow, possibly causing overheating. Some PSUs may not even need the vents. So really it depends, but adding some baffle to prevent bugs from entering would be prudent.
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
    • shamsudeen
      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
      by shamsudeen
      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
      i know that in linear power supply the noise will be very low comparing to SMPS supply....
      07-19-2025, 07:14 AM
