Caps from China
  • Maxxarcade
    • Jul 2006
    • 973
    Caps from China
    Just got in some new United Chemi-Con and Vishay caps, and all of them are apparently made in China. I thought UCC was Japan, and Vishay was USA? Is everyone bailing out to cheaper manufacturing these days?
    Is there a way to find parts that are made in USA, Japan, or other reputable factories? Seems like it's becoming pretty rare to find any lately.
  • japlytic
    • Oct 2005
    • 2086
    Re: Caps from China
    Chemi-Con history: http://www.chemi-con.co.jp/e/company/history.html
    Chemi-Con factories: http://www.chemi-con.co.jp/e/jigyou/global.html
    Generally, the overseas factories are under supervision by Nippon Chemi-Con.
    • mbates14
      • May 2005
      • 169
      Re: Caps from China
      I guess the bottom of the line is this: Unless you make your own, expect the unexpected.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Re: Caps from China
        uhh... samxons are china and they are fine... the exception, not the rule i guess...
        sigpic
        (Insert witty quote here)
          • 31277
          Re: Caps from China
          i'v dealth with the chinese.
          they are proud people who will supply anything you want.
          the problem is management - not chinese management, but any management.
          if you ask the chinese to make you the best product then they will,
          and if you ask them to make the cheapest shit possible that still functions - they will.
          the problem is company's that try to screw every penny from the customer by asking the factory's to produce the second variation of the product.
          have you seen the song class submarines?
          they scare the crap out of the u.s. navy - they built that without fuckyou capacitors i'm sure!
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
