ESR and ESL
  • cadiman
    • Mar 2010
    • 397
    ESR and ESL
    Issues with capcitors were few and far between for me in the past. I find this forum and suddenly I am finding bad caps. I remember all capacitors being the same up to a frequency of 10khz. Esr and esl were important as frequency rises. I don`t see anything here about esl (inductance) and was wondering what effect is has on curcuit performance.
    Could someone point me in the right direction here? Thanks, Cadiman
  • reessi
    Huawei D14 - DAH98AMBAD0 Rev.D - Laptop not Charging - Missing 137K on IADPT - Inductance Selection - BQ25713 Charging IC
    by reessi
    Hello:
    On the above laptop which wasn't charging I found only a tiny drop of water damage exactly on a few components by the BQ25713 Charging chip.. Bizarre how only that one 3mm square for it but it did..
    I looked up the BQ25713 datasheet and replaced the 10K pull up resistor on the CHRG_OK line and now it charges!
    But on the IADPT line which seams to be a resistor (137K) to tell the chip which Inductor is in use it is corroded also.. (Inductance Detection Through IADPT Pin - from datasheet).
    So my question is what are the implications of leaving...
    03-06-2024, 07:33 AM
  • dennis_elx33
    3PHASE STEP-DOWN Transformer in Check
    by dennis_elx33
    Hello All,
    i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
    Problem statement: Power tripped Off
    Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
    Action Done:
    1) Replaced the faulty parts with good spare.
    2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
    12-02-2024, 06:52 AM
  • quickname
    Cyberpower 1500AVR UPS repair
    by quickname
    I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
    I decided to verify that the batteries were...
    11-12-2023, 09:57 AM
  • madfreak
    ASUS FX504GM not turning ON
    by madfreak
    Hello everyone...i will start a series of posts with laptops that are my nightmares .
    This time i have a laptop ASUS FX504GM after burned mosfets in the CPU power supply section.
    Laptop motherboard model : DABKLIMBAB0 REV. B
    CPU : i7-8750H
    GPU : GTX 1060
    Laptop history : Laptop has burned mosfets (including hole in the motherboard) near the CPU.
    The burned mosfets were exactly : PQ94, PQ95, PQ96
    After few hours of work ( restoring pads, connections, and removing shorts ) finally i have tested motherboard...and...
    08-14-2023, 04:27 AM
  • claws77
    LED driver board, orient electric, 7W
    by claws77
    datasheet= https://www.alldatasheet.com/datashe...C/SIC9753.html
    i have tried to make the schematic similar to typical application
    A1 = varistor
    V_C5 _measured wrt -ve = 57-60V pulsating DC, VDD_measured wrt GND_IC = 12-14, VDD_measured wrt -ve = 60-62V pulsating, V_Drain wrt -ve =309V,
    1. L2 is unknown, how to measure inductance with multimeter?
    2. what is happening after rectification and varistor? what does this IC do? how does it provide constant current ?
    3. R8 36Kohm is to discharge the capacitor C5 100uF only, right?
    4. how to test if this IC is
    09-29-2024, 05:23 PM
