Ni-Cd Power Supply Resistor
  • kodiac
    • Jul 2010
    • 116
    I would like to know how to calculate the value of resistor R1 in the enclosed Ni-Cd Power Supply photo.
    Thank You
  • kodiac
    • Jul 2010
    • 116
    Re: Ni-Cd Power Supply Resistor
      • Jul 2011
      • 6070
      Use an online ohm calculator you need
      18 volts @ 500 milliamperes or
      25 volts @ 500 milliamperes the resistor value will a little bit higher
      Use at least 2 watt resistor for this device at a minimum
      If you use this method above do not leave the battery on the charger continuously this will shorted the life of the batteries
      However you would be better off if you used something like a LM317 voltage regulator in current mode this will give you better current control which can also be found on how to use it in current mode in the data sheet for this device
      If you use a voltage regulator in current mode I would recommend that you use 50 milliamperes and 500 milliamperes if you want to leave the battery on the charger all the time use the 50 milliamperes mode and if you want a faster mode charging mode use 500 or 750 milliamperes just make sure that you switch it back to the lower current mode after charging if you leave it on charger
      I hope this helps you
        • 31283
        14ohms
        and it's going to generate 9w of heat!
        (so maybe consider a chinese intelligent charging module instead!)
          • Jul 2011
          • 6070
          Originally posted by stj
          14ohms
          Here is one of these chargers
          https://www.ebay.com/itm/23346573025...IaAq7rEALw_wcB
          One note about these battery charger do not get the idea that you can put a led on the charging board remove all components from the device board and use jumper wires because if you do not do this the charger will not work correctly I have tried this before and the results were that the charger keeps charging the battery instead of lowering the current when fully charged or refuse to charge the batteries
          If this person is building from ground up and designing this charger to charge nicad batteries the same thing will hold true do not add a led at the battery pack you would have the same exact results
            • Jul 2011
            • 6070
            Here is the website link to the connector for the charger from the same seller
            https://www.ebay.com/itm/23416696459...53.m2749.l2649
            I have bought some of these myself
              • 31283
              for that money you could get a B6 clone!
              • kodiac
                • Jul 2010
                • 116
                My diagram is of a Jobmate Ni-Cd charger
                Board # KW14-V0
                R1's outside coating has burned away,leaving no color code bands
                In circuit R1 measures 3.9 ohms
                Are these formulas correct
                VR1=1.17 x Battery Voltage + 3.3v
                R1 = 3.3 / (1/4 of Battery Voltage)
                Thanks to everyone for your information.
                  • Jul 2011
                  • 6070
                  Board # KW14-V0
                  Okay
                  Like what was mentioned earlier in this post if just replace the resistor the same exact thing will happen again because this is the cheapest way to charge a battery which has all kinds of issues
                  • kodiac
                    • Jul 2010
                    • 116
                    Thank You
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                    • JimBanville
                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                      by JimBanville
                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                      09-13-2023, 07:21 AM
                    • jinu_j
                      by jinu_j
                      Hi
                      05-03-2025, 10:51 PM
