Here is a good used source for 18650 batteries
  • eccerr0r
    replied
    Re: Here is a good used source for 18650 batteries
    hmm... need to add a place for a screw terminal barrier strip for reconfiguration and strain relief...
    Torn right now whether to use it as 2p 24V or 2s at 48V... so many things need power...
    replied
    Originally posted by eccerr0r
    Oh... never ever ask me about finished products. Even if it is designed well, it will look like something that belongs in the ghetto mods thread
    I am no better than you about this ( functionality to me is more important than anything else anyway )
  • eccerr0r
    replied
    replied
    Not really much of a design but swiped an existing design on thingiverse and something like this will hold the two packs together...
    I am also taking about when you have the finished product also thanks
    I am also going to be on vacation next week and I will have time to finish one of the projects that I have been work on for last week or so that I have been testing the two half battery packs that I modify and I have the test results and will be about 30 amp hour battery pack I just have to hook up the BMS protection boards and charging controller in the enclosure if it will fit if not it will be external mounted
  • eccerr0r
    replied
    replied
    At 175W it'd take a while to boil, though it's not really meant to heat food, it was meant for 3d printers...
    Anyway I need to make a receptacle for the packs so they can be more used together. 3D printing time...
    Can you please post some pictures of this when you finish this because I would like to see what you came up with
  • eccerr0r
    replied
    replied
    Put a pot of water on the hot plate and let it rip until the battery voltage drops to around 18 volts and time how long it takes to get to that voltage and you can then estimate how many amp hours they have
    The battery packs that I made modifications to I get around 14.5 amp hours which is not bad for the price I paid for them
    Now that I know how to modify them the easiest way I am going to make two 20 volt battery packs for the air compressor that I have talked about before
  • eccerr0r
    replied
    I hooked up the two 24V packs in parallel and fed it to a 24V hot plate I had... it drew about 7.5 amps - about 175 watts from the packs. The set of packs drooped ~0.6V. Not great but it did pump out the watts, now not sure how long it can sustain it.
  • eccerr0r
    replied
    Supposedly these packs are new, hence the "premium" price - I paid far less for the other packs though they hold far less too, though they should likewise be new.
    Looking at the Despot these packs are like $400/kWh OUCH... though granted one of the two packs at the liquidator was an off brand.
    replied
    Ooh... now the local shop has two 40V 6Ah li-ion packs for Ryobi tools... alas they're not at a price I'd pay for just storage capacity as I don't own Ryobi tools. To buy the packs out it's about $200/kWh which is way out of my range...
    I have done a Forensics investigation into these battery and they are not a good choice for harvesting battery cells from because either the batteries fail or the BMS protection board takes a shit and destroy the batteries I am not sure exactly which one happen first
    A better choice it there 18 volts 6 to 9 amp hour batteries these BMS board are made a little bit better and NOT always destroy the batteries when they fail they just do not put out power most of the time at least the ones that I have repaired because of mosfet failure
  • eccerr0r
    replied
    I did snatch up a 10S charger brick from there today however. Who knows if I someday get a 10S pack or modding to a different voltage is never out of the question...
  • eccerr0r
    replied
    oh it was that local shop that closes out stuff, so they only had one (or actually, two, but they were bundled) ... so not a good place to get cells. TBH not sure about the effort, have to scan them in person for new inventory to see if they just so happen to have li-ion packs or not. So yes I had to pay sales tax on them. And my car was the shipping fee...
    replied
    I didn't order from there, shipping cost was too high.
    Can I ask you where you got your batteries from
  • eccerr0r
    replied
    replied
    Did you get your order from BH yet
  • eccerr0r
    replied
    Dont think it will push enough hot air for freezer defrosting, but who knows.
    I wonder if I can pop popcorn with a hot air popper at 48V though need to put less corn in the chamber as there won't be as much hot air...
    replied
    Tried to connect the two packs in series for 48V and fed it to a 1500W @ 120VAC RMS heat gun. It drew around 4A for about 175W and yes it spit out quite hot air. That is about the limit at 48VDC into a 120VAC device. As for capacity, not sure how long it can maintain this power... and now need to find something that can draw even more power...
    I have to try this myself with the two battery packs that I just bought and see how well this would work for a testing load the next time I defrost my freezer who knows it might work better than I think
    replied
    Well I just received the two battery packs and they are charged up 51.something and each battery of cells are 3.9something to 4.something so I am ready to test these batteries over the weekend
    ( maybe I have to test some other batteries that I am having some issues with so I can get an adjusted refund on this battery pack that I mentioned earlier in this or another post )
    This is the way these batteries come most of the time the first one that I got was only 49.something volts but they had sat for about 4 months before I did anything with them and they have tested good so I just have to get the BMS protection board wired up and put it in its enclosure
    ( which is made for these battery packs ) that I also bought from BH and put the battery hookup wires and ready to be put in service 15.something amp hours to 16.something amp hours
    The way I have them configured so with both half’s they will total to about 30.something to over 32.something amp hours
    The only time that I get concerned about battery that I get from BH is when the battery voltage is below 2.5 volts or below this but have some that are so low because the BMS protection board are bad and have run them down this low and have to take them apart and cycle them a few times and they should be ok
  • eccerr0r
    replied
    Well, once again, trying to use the existing hardware especially if the cells aren't up for more anyway.
    I have a few XT90s to play with if needed but curious how much those blade connectors can go. Ease of assembly (eject/insert battery) is probably the main focus of these connectors versus current capacity, though it may well be "enough" ...
    Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
    by sam_sam_sam
    I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
    I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
    12-31-2023, 06:04 AM
  • flat-earther
    Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
    by flat-earther
    I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
    To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
    I have opened the camera and I think there is enough room to add something inside to accomplish this:
    The camera is powered by a 3.7V nominal single cell lithium ion battery.
    So I need to connect another battery in...
    06-08-2025, 02:00 AM
  • mkdj
    ASUS X571 no power : battery issue?
    by mkdj
    Mark and model: ASUS X571
    Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
    Tests already made:
    - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
    - I have removed...
    07-14-2025, 09:16 AM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
    Cyber Power ST625U Battery backup battery when bad so I going A123 type battery pack
    by sam_sam_sam
    I have had this battery backup for at 2 to 4 years now and the battery when bad and this is weird battery size it is the same length as a 12 volt @ 7 amp hour battery however the depth of is not the same as a 12 volt @ 5.5 amp hour battery
    I have several battery packs that are A123 batteries cell so I bought a lipo4 BMS balancing protection board for these batteries and I have a configuration that is 4S 3P these battery packs were 3S 2P so I reconfigured them but left the tabbing on one side of the battery row of battery cells and re-tabbed the other side to the configuration that...
    06-18-2023, 05:48 PM
