Mosfet marking AOP (AUQ) datasheet or ID
  • m3g4tr0n
    • Aug 2011
    • 88
    looking for datasheet or ID of the chip has marking AOP AUQ. I checked on two other boards that i have and they show AOP AUR and AOP AUK.
    or its A0P?
    thanks
    • 22108
    Re: chip marking AOP (AUQ) datasheet or ID
    or its A0P?
    thanks
    Is it on a laptop motherboard
    • m3g4tr0n
      • Aug 2011
      • 88
      Re: Mosfet marking AOP (AUQ) datasheet or ID
      it's on an Nvidia Shield.
      attached a picture of voltages on a working board.
      on the non working board, i have 5v only on pin 3 (under letter Q). other pins read 0 volts.
      • R_J
        • 9623
        I found the Micrel MIC5320 that is a dual output regulator, but has the wrong pinout
        • m3g4tr0n
          • Aug 2011
          • 88
          just an update on the image with voltages. 1.8v should be 0.8v and pin with 0v should be between 0.4xV to 1.xxV voltage changes depending on load?
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
            by SMDFlea
            Bad...
            09-02-2021, 04:40 PM
          • Troystain
            Help EZP2023+ updated chip database for w25q256jveq?
            by Troystain
            Hello, anyone here have updated ezp2023+ chip database in .dat file format.
            I need to add w25q256jveq chip but I do not know what data should I type.
            I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
            The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
            11-25-2024, 12:53 AM
            Renesas H8S/2112 R4F2112 R4F2112R - 16-Bit Single-Chip Microcomputer Datasheet
            H8S Family / H8S/2100 Series
            Ordering codes:
            F2112TE25V F2112BG25V F2112LP25V
            The core of each product in the H8S/2112 Group of CISC (complex instruction set computer) microcomputers is an H8S/2000 CPU, which has an internal 16-bit architecture. The H8S/2000
            CPU provides upward-compatibility with the CPUs of other Renesas Technology-original microcomputers: H8/300, H8/300H, and H8S.
            As peripheral functions, each LSI of the group includes a serial communication...
            10-23-2024, 02:33 AM
