why the silicone sealer on pcb boards ?
  • petehall347
    • Jan 2015
    • 4448
    wondering why the battery packs i have been looking at have a coating of white silicone type stuff covering them ? its just i had to remove it from a board to repair it and wondered if and what i should replace it with ?
    these are the 80v power tool packs .
    only thing i can think of is to help stop bits falling off with the vibrations from the tools .
    p.s it comes off ok with petrol and an old toothbrush . and patience .
    • 31280
    Re: why the silicone sealer on pcb boards ?
    probably to keep moisture out of the circuits.
    • petehall347
      • Jan 2015
      • 4448
      they appear to have been clear lacquered first then the white stuff .
        • 22096
        liquid electrical tape is what you want, good stuff but fairly expensive .
        • petehall347
          • Jan 2015
          • 4448
          do i actually need to use the white stuff or can i just use the pcb lacquer ? as that would surely keep out damp as that's what it is for .
          it crossed my mind whether it is used to hold back fire in case the boards decide to go up in flames .
            • 22096
            yes you could just use lacqer.if you want to fill it with silicone get some specially for pcb`s ,neutral cure RTV.
            • petehall347
              • Jan 2015
              • 4448
              thinking of getting this one as will need more in the future . https://www.ebay.co.uk/itm/293436685...IAAOSwbTVeJ2zH
                • 31280
                that's some nasty shit - you have to use it outdoors!
                i use a chinese version of this:
                https://www.aliexpress.com/item/32949184183.html
                • petehall347
                  • Jan 2015
                  • 4448
                  outside is fine for me .. well so long as its not raining that is .
                  • ugamazing
                    Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                    by ugamazing
                    I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                    We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                    12-17-2024, 07:05 PM
                  • ugamazing
                    Apple M1 Boards & Exclamatory Error?
                    by ugamazing
                    We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
                    Has anyone else run into this...
                    02-20-2025, 09:24 AM
                  • ugamazing
                    Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                    by ugamazing
                    I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                    08-31-2022, 07:34 AM
                  • TVAddict
                    UN65NU6900F - Backlight No Picture
                    by TVAddict
                    Set turns on normally, backlight stays on, after about 20secs or so thin vertical colored lines appear on the left side of screen.
                    First i tried disconnecting the lvds ribbon cables one side at a time to see if i would at least have half a picture, i got nothing.
                    Hooked both back up and started probing voltages on both ribbon cables, got nothing, disconnected one and got all the main voltages/signals on both ( supply - 3.2v, 26.2v and 1.8v for signals).
                    So started checking for shorts on this side - right driver board, mainly caps, nothing found, so...
                    03-10-2022, 11:13 PM
                  • hopkok
                    Legion 5 PRO, 3 boards, same problem, NM-D562 Rev. 3.0 motherboard
                    by hopkok
                    Hi friends, last week I got 3 same boards for repair (NM-D562 Rev. 3.0), same problem, power button light up, but motherboard wont start.
                    3,3V_alw and 5V_alw, 1,8V_alw and 0,75V_alw presented on all 3 boards, no other voltages. 1,2V missing and if I checked schematic right, I need 1,2V and than can be +3VS and +5VS generated after getting SUSP_N signal from KBC? or vise versa?
                    I checked for low resistance on coils, no low resistance.
                    Anyone with same issue like me?
                    Thanks for any help.
                    05-24-2025, 04:21 AM
