RT809H Programmer Not Detecting Any Chip
  • shani
    • Nov 2017
    • 10
    Hi guys
    My RT809H is not detecting any chip. Whenever i try to detect any chip it's keep showing me messages.
    Chip pins is detected poor contact, operation has been terminated.
    chipPin: 6-30-24
    Chip ID identified error, the chip not well placed or has been damage.
    No matter which chip i use or which adapter i use it's keep giving me random messages and random errors.
    If you look at the picture 1 and 2 same thing happen here is well. random errors here is well.
    when i bought new i used only once and even then it wasn't reading any chip.
    I have tried 2017,2018,2019,2020,2021 version software ;(
    it's showing 4.8v with usb cable, is it enough voltages to run this programmer or do i have to give external power is well.
  • mon2
    • Dec 2019
    • 14877
    Re: RT809H Programmer Not Detecting Any Chip
    The VUSB voltage is fine.
    Do you have other USB cables you can try? Consider to use the shortest cable you can source and if possible, a branded or known good cable.
    There is so much garbage in the USB cable business. A good cable will be truly USB IF certified which implies that the proper shielding, etc. are in place for the cable assembly.
    Next, it is possible that your programmer is a dud. Perhaps can be fixed once you take it apart (carefully) to review the soldering onboard. Perhaps a dry solder connection or two.
    Be sure that you are placing your device to be tested (read / write, etc.) properly inside the zero force socket.
    • shani
      • Nov 2017
      • 10
      Thanks for your reply, I will try with different cable. I bought this from HKLRF.com but used only once. after two year i try to use it and it's showing these random errors. Anyway i can't really return this product so i will open it and see if any dry solder problem with this programmer as you mention. Thanks again for your help
      • 5chematic
        • Jun 2019
        • 77
        Originally posted by shani
        Hi guys
        chipPin: 6-30-24
        Hello there shani,
        What a coincidence, I came across this problem, the same software and the same everything. I have considered this software one of the worses softwares when it comes to programmers. I have tried everything. I made it work only two times. depending of what type of board you are working on, I recommend to inject voltage to the chip.
        • bogdanivan31
          • Nov 2012
          • Romania
          How did you solve the problem with the rt 809 h defect
          • PitiCom
            • Mar 2019
            • 26
            • Sri Lanka
            Hi guys
            chipPin: 6-30-24
            try on another PC,
              • 31305
              test it with a dip packed chip that doesnt need any adapter.
              adapters are a pain in the ass with pin detect errors - the more pins the bigger pain.
              i specially hate reading 48pin Tsop chips!
              • newdes
                • Aug 2018
                • 34
                • MX
                Hi, could you help with this problem? My RT809H isn't detecting any chips.
                I've tried it on two other computers and with different USB cables.
                I cleaned, disassembled, and reassembled it. I've visually checked for any damaged components.
                I've also checked all the resistors with the correct values and they're all correct. Does anyone know what it could be?
                Help :C
                Log:
                001: Align to the bottom of ZIF,disable placed at random function.
                002: Chip pins contact is detected OK.
                003: chipPin: 4-28-24
                004: Align to the bottom of ZIF,disable placed at random function.
                005: Chip ID identified error, the chip not well placed or has been damage.​
