Ryobi cordless driver drill cbd-120vr
  • GEARELECTRONICS
    • Apr 2019
    • 13
    • seychelles
    I am looking for the two resistor values located on the small board inside the battery charging stand.
    Please help if you know
    thanks
    • Jul 2011
    • 6040
    Re: Ryobi cordless driver drill cbd-120vr
    Please post some pictures of this device
    • GEARELECTRONICS
      • Apr 2019
      • 13
      • seychelles
      • GEARELECTRONICS
        • Apr 2019
        • 13
        • seychelles
        please find attached relevant pictures for RYOBI CORDLESS DRIVER DRILL
          • Jul 2011
          • 6040
          I personally would recommend modifying the charging current and not using a resistor to do it
          I would use a LM317 in the current mode and set it 500 to maybe 750 milliamperes at the most
          If you have the battery on charger all the time then I would recommend not going more than 300 milliamperes at the most probably be better 150 milliamperes would be better choice
          Or use a readymade current controller board and just remove the power jack and wire it to current controller board
          Ok one resistor is for the led and the fatter one is the current resistor for charging the battery
          One note you need to check the diode and make sure it still works correctly
          When I use to use nicad battery pack and had charging boards like this
          I would make a little board with a LM317 and set it up to 150 milliamperes and have more than one battery pack and
          I would be rocking and rolling again
          I would have a LED that would light when the battery was on the charger and basically when the battery was fully charged it barely be light or you would not see it light anymore
          How you set this to work correctly and let you know your battery is fully charged you put the LED light with resistor in series LED and put this in series with the regulator input pin and the output pin side or it is the adjust pin I do not remember which pin you have to use output/adjust pin which pin to use but it is easy to figure out which pin to use is when the battery is on the charger it should be lighting up the resistor should 1k ohm for the LED light bulb
          The current resistor for the output pin to adjustment pin there is a forum on the data sheet so you can figure out what value you need to use for a certain amount of current
          • GEARELECTRONICS
            • Apr 2019
            • 13
            • seychelles
            THANKS a lot for your interest, the diode tests ok.
            The fat resistor is reading 3.5 ohms.
              • 31040
              that's terrible.
              what does the battery say on it?
              i'm thinking a proper charge circuit is needed.
              • GEARELECTRONICS
                • Apr 2019
                • 13
                • seychelles
                Battery says 12v
                  • 31040
                  nothing else?
                  i want to know the chemistry.
                  lithium, NiMH, NiCd etc.
                  different chemistry needs different charging circuits
                    • Jul 2011
                    • 6040
                    Originally posted by stj
                    nothing else?
                    It is a nicad battery pack I use to have there 9.6 volt battery pack way back when Sears way back when had this style as well
                    I would hope that no manufacturer in there right mind would use this method for charging lithium batteries of any kind you are just asking for problems that would be a big mistake if you do not at least have a protection board at a minimum
                      • 31040
                      well i'd open the pack and count the cells - dont trust the label.
                      then go on ali and find an intelligent charging module.
                      it's worth opening the pack anyway to check they arent "flowered" all over the casing!
                      if it only has 8cells then you can get a nice charger module that runs from 5v
                      however, if the diode and fat resistor are o.k. then the battery or drill may be the problem.
                      or even the psu
                        • Jul 2011
                        • 6040
                        I have tried these module before and I was not impressed with the performance results I was getting with them
                        The biggest issue that I had with them is that they tend to under charge them and because of this running time was crap
                        Unless you know where to go and get good quality one that charge the battery correctly I would interested in buying some because I still use nicad for some applications because of voltage limitations
                        And do not cost an arm and a leg for the cost of them
                          • 31040
                          i have one of these: it gets the job done.
                          https://www.aliexpress.com/item/4000283329984.html
                            • Jul 2011
                            • 6040
                            Thanks for the website link
                              • Jul 2011
                              • 6040
                              No I have not because I do not any of there tools I am sorry I can not help you with this
                              • osrex
                                LED DRIVER KEEPS DYING
                                by osrex
                                Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                                i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                                i have no datasheet at all for the LED lights, all i have is its length.
                                long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                                as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                                05-05-2025, 03:36 PM
                              • DXseekerMO
                                Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                                by DXseekerMO
                                Hello everyone!
                                Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                                Symptoms:
                                1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                                2) TV does not appear to turn on
                                3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                                4) "Power on" terminal on Power Supply has 3.26v
                                5) "A13V" terminals have 12.9v
                                6) Stand-by test jumper on Power Supply has 12.9V
                                7) Optical audio jack on Main Board illuminates
                                8) With stand-by...
                                06-09-2021, 12:19 AM
                              • flat-earther
                                help repair Scorpion SC-6989 12v cordless impact driver
                                by flat-earther
                                Hi I got this Scorpion High Quality Products model SC-6989 12v impact driver and the problem is it only runs on full speed and LED light doesn't light up.
                                I got the tool with two dead batteries and I already using the good 18650 cells from the two made one working battery.
                                Initially when I got it I once hooked up a good 12v battery to it and it powered up and LED worked but now depressing the trigger only makes it run on full speed or nothing so there's no variable speed, but to be honest I'm not sure if this tool has a variable speed trigger. Also LED doesn't light up anymore....
                                03-06-2023, 06:57 AM
                              • howardc64
                                Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                by howardc64
                                Problem
                                Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                Model & Board Pics
                                Conflicting Spec
                                Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                https://www.shopjimmy.com/vizio-gj-2k1...
                                10-10-2024, 01:16 PM
                              • charif
                                Audio Driver for Thomson P14C4BK128
                                by charif
                                Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
                                I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
                                The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
                                Here are the details:
                                • Model: Thomson P14C4BK128
                                • Operating System: Windows 10 64-bit
                                If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
                                Thanks in advance for your help!
                                04-30-2025, 05:41 PM
