Can I replace this SMD Package Capacitor with this??
  • gersrt
    • Jan 2021
    • 22
    • Ireland
    Hi
    Still learning so soldering skills not great. I need to replace the following SMD capacitor on a board, but because of size I would rater not use an SMD type.
    The capacitor I need to change is 1000nf 50v 2012 x7r smd type.
    https://www.ebay.ie/itm/174298527078...6&toolid=11000
    Could I use this instead and if not can someone point me in the right direction.
    Many Thanks
    • 31283
    Re: Can I replace this SMD Package Capacitor with this??
    probably,
    i mean the ebay part does not say it's x7r type, but that's not too important.
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • chth96
      Is it no harm to replace with capacitor without ripple current rating?
      by chth96
      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
      Rubycon YK DataSheet (b...
      04-19-2024, 05:19 AM
    • chth96
      by chth96
      12-22-2023, 04:34 AM
    • chth96
      Should I replace polymer capacitor?
      by chth96
      a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
      I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
      Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
      Is this ESR value of polymer capacitor correct?...
      11-18-2022, 04:22 AM
    • cap__
      Can I replace 15uf capacitor with 22uf?
      by cap__
      "If I wanted to replace an old 15uF/400V capacitor with a new one,
      I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
      11-29-2023, 11:16 AM
