D-Link DGL-4300 Gamer Lounge
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    Hi
    I found a 4300 yesterday that had non working lan and wan ports, the wireless works perfect and there are no problems logging on to it and upgrading firmware.
    However the lanports never woke up so I took it apart and saw 2 caps that are blown.
    The caps on the left are ok but the two on the right are blown.
    Close up of the two blown caps.
    I guess by soldering off one on the left side and measuing it and ordering two new ones I can maybe fix this router.
    However I don't understand why they have caps from ground to ground !
    I'm not very good at understanding circuits,are you ?
    Can I put a wire over the two blown ones to test lan/wan ports or will this for sure damage the box ?
    Gab
    • 31013
    Re: D-Link DGL-4300 Gamer Lounge
    it's to block dc current - they are probably .1uf
    and they blew because of an earthing fault / current loop between the devices connected to it.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      or a lightning zap.
      • Gabriel
        • Jan 2010
        • 620
        • Norway
        Have not been able to fix this yet, replaced the ip101 ethernet transceiver but still no go sadly.
          Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
          This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
          09-07-2024, 05:00 AM
        • cmlewis89
          LG 47LB5DF blown power supply board
          by cmlewis89
          Hi folks,
          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
          09-03-2024, 07:50 PM
        • drscoot
          HP X360 convertible battery blown fuse error, not charging
          by drscoot
          HP Modelnumber: 14-dh0061nb​
          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
          All these 3 batteries are charging...
          12-15-2023, 05:54 AM
        • swerg
          Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
          by swerg
          Hey everyone,
          I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
          I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
          I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
          06-06-2024, 03:39 PM
        • MrzPdlch
          Blown fuses on Gigabyte GTX 980TI 6GB
          by MrzPdlch
          Hey everyone,
          I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
          Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
          Find some pictures of the actual GPU together with a picture of how it should look like.
          I also wonder whther it might be a problem that there...
          03-10-2024, 04:14 PM
