Repurposing an IPAD Air 2 any ideas feedback wanted not wanting to recycle
    • Jul 2011
    • 6070
    Is anyone on this forum that has repurposed an iPad Air 2 or any version of an iPad
    If so can you please go into some details of what you did and what application you used if any
    I have googled this topic and have got some ideas but I looking for more ideas
    One idea have is to use it as multimeter data logger which I already have the meter for this purpose
    Another I use as a music listening device for music that has been purchased
    Or doing both idea
    • 31281
    Re: Repurposing an IPAD Air 2 any ideas feedback wanted not wanting to recycle
    root it and you can install a terminal on it for serial logging.
    and install gridrunner on it too.
    • japlytic
      • Oct 2005
      • 2086
      For some time, notebooks/tablets/all-in-one PCs have used LCD panels with an Embedded DisplayPort (eDP) interface which typically has a standardized pinout except for manufacturer use pins which are typically left unconnected in normal use - for this model of tablet, the display resolution is quite good for the viewable area; a compatible display controller is available to repurpose the panel.
      One final word: the right to repair should also extend to the right to repurpose.
        • Jul 2011
        • 6070
        I did find a purpose for this iPad but I play hell do it
        The first problem was it was my son’s iPad and he had forgot the password but for some strange reason I happened to remember what it was but because it had not been used in several years the iCloud connection was locked and could not be reset correctly anymore
        So I send Apple support a reset request ( use this option when nothing else works this is a pain in the a** to do )
        You have to wait 7 days for Apple support to make sure that it is you the owner of the iPad and then they set it up so that you can reset the iCloud password
        I finally was able to get the iPad back to do a factory reset and setup the iPad for a new purpose
        What I have done is turn into a Fluke data logger and a Own meter data logger
        This is only thing that is on besides the the application that comes with the iPad to begin with
        • GeirAndersen
          iPad .pcb file collection
          by GeirAndersen
          I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
          Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
          IPAD COLLECTION 1
          +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
          +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
          +---iPad mini3 820-00008(A1599) 820-00002(A1600)
          +---iPad mini4 820-00180(A1538) 820-00177(A1550)
          +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
          +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
          12-09-2024, 09:28 AM
        • grimacelord
          Apple iPad Pro 3rd Generation 12.9" (A1876) No Power/Charge When Screen Is Connected
          by grimacelord
          Hello.
          Working on an Apple iPad Pro 3rd Generation 12.9" that has a weird issue. When the display is NOT connected, the iPad will charge and power on normally. I know it's on because I can hear notification sounds and the charging notification sound.
          If I connect a brand new display to the logic board, the iPad will not turn on at all. When I connect the iPad to an 18W wall charger and a USB-C ammeter, I can see that the iPad is attempting to charge, but constantly "resets" after just a moment or two.
          For example, when I connect the iPad to...
          04-15-2022, 11:06 AM
        • trepachka
          iPad Air A1475 Boot loops after replacing battery
          by trepachka
          This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
          The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
          I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
          11-08-2024, 03:17 PM
        • ipatch
          ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
          by ipatch
          i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
          08-24-2024, 02:36 PM
        • SarcasticOP
          iPad Pro 12.9 (6th Gen) screen shuts off after unplugging device
          by SarcasticOP
          Greetings,
          I have an iPad Pro 12.9" 6th gen tablet that had a screen replaced about 10 months ago at a repair shop and last week the screen went blank during use. The device was still on, notifications played sound for example. I have replaced the screen twice, both screens are working until I unplug it, at which point I can see that screen is on but is all black. If I press the power button, the backlight goes off, and when I press it again, the image appears for half a second and then the screen goes back to being black but on. This issue is not present at all when the iPad...
          10-24-2024, 11:55 AM
