ESR Meter CAL.
  • bogart219
    • May 2009
    • 200
    • usa
    ESR Meter CAL.
    Yellow all and happy new year.
    I have the older Dick Smith ESR meter, the one that is black with the red led display. Is there any way I can calibrate this meter to make sure its accurate?
    Seems I've been getting a lot of caps lately that reads the same value. Thanks!
  • Krankshaft
    • Jan 2007
    • 2328
    Re: ESR Meter CAL.
    When the meter was purchased a 1% tolerance calibration resistor was included. 82 ohms I believe you turned on the meter zeroed out the probes and measured the resistor.
    Then you turned the CAL pot until it read 82 ohms. Then you used another 5.6 ohm 5% tolerance resistor to check your work.
    There are two POTs on the board though the other one is for the low battery threshold leave that one alone.
    I get those low readings too on my blue it's because the caps are so low ESR they're almost out of the meters range like. 0.01 could be 0.010 but you don't have that extra digit.
    This is a tool to sniff out bad caps whose ESR usually goes way up from decimals to whole numbers. So if you see something that low the caps are fine.
    • bogart219
      • May 2009
      • 200
      • usa
      Re: ESR Meter CAL.
      Thanks for the info Krank
      • Agent24
        Dick Smith Q-1760 linear power supply filter capacitor question
        by Agent24
        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
        It has at least one problem.
        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
        I have already ordered a replacement potentiometer, so that's not an issue.
        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
        All are CapXon...
        10-21-2025, 05:39 PM
      • jinu_j
        by jinu_j
        Hi
        05-03-2025, 10:51 PM
      • mikey5791
        Need help to replace burned resistor in 350w atx psu
        by mikey5791
        Hi to all forum members,
        Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
        The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
        Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
        Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
        12-26-2024, 04:55 AM
      • MidnightRoller
        Can a resistor lose resistance after hot air?
        by MidnightRoller
        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
        02-02-2022, 11:46 PM
      • artvandalai
        What resistor ohm will work better to repair this waterpik?
        by artvandalai
        The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
        01-05-2025, 04:10 PM
