i have a question on power supply specially in trouble shooting audio equipment/ can i use boost converter of just a linear power supply. boost converter psu has higher efficiency, current and much colder than linear psu,, what are the disadvantage of using boost converter in audio equipment. thanks in advance
Never stop LEARNING because life never stops TEACHING!Tags: None -
Re: Anyone build their own equipment? Plans for small benchtop power supply.
Boost converter??
Are you boosting a lower voltage to a higher one? (Such as car subwoofer audio amps do.)
Or are you talking about a buck converter / buck regulator / switching regulator for lowering voltage?
I suppose that question is irrelevant, but I am just curious since you specifically mentioned boost converter and not the more generic term (switching regulator / SMPS.)
As for disadvantage of using switching regulators in audio... that depends a lot on your application and what device you're trying to power. If your audio device has anything to do with AM radio, you would probably want to avoid any kind of switching PSUs and regulators, as these tend to kill AM reception (though if carefully and well designed, it may not affect AM radio reception that much.) I ran into that problem with an old late 90's boombox that I converted to use an external SMPS adapter, detailed here:
https://www.badcaps.net/forum/showthread.php?p=997901
Other than that, and as long as the audio amp isn't overly-sensitive to noise and the switching regulator is designed to have enough filtering on its output, then you may not see that much of a difference between that and a linear regulator.
But again, going by description of what you're trying to do is rather vague, so it's hard to give a more solid answer. -
Re: power supply specially in trouble shooting audio equipment
Posts moved to a new thread..Comment
by BOSCHNJAKABOUT ME INTRODUCTION FILE
2024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
2022 BEV, PROJECT ?
2021 BEV, PROJECT ?
2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...-
Channel: Visitor Messages
12-28-2023, 02:09 PM -
by yihuilinHello Every Genuis
I have a laptop from my friend, model is "HP 15-dy0013dx" , Logic Board model is DA00P5MB6D0 REV
MODEL: 0P5
this Laptop come with a BIOS Warning issue, the Keyboard CAPS LED Blinking 3 times slow, 2 times fast , don't remember exactly, someting like this, has a Meaning , also Fan will run
but I googled, people says this Meaning EC have a issue to read BIOS, so I use CHA314A programmer to read and write (wrote the same content file read from BIOS), after I flashed the BIOS, the CAPS LED doesn't blink anymore
The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...-
Channel: Common Parts Library - Datasheets
10-23-2024, 03:23 AM -
by gizmo1990I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short... -
by wolf1976hi
in an inverter of aircondition i have dc to dc converter mes1515mh
i have attachment the pdf file
can i take a dual converter with two dc outputs instead this ? because i cannot found the same or is not possible ?
the problem is instead 15 volt dc output i have only 6,45 volt
thanks on advancxe... - Loading...
