Help identify Christmas light wiring
  • mikey5791
    • 515
    • Malaysia
    Yesterday i went through storage and found this old christmas multi function lighting set
    with a light controller box, but the neon light bulbs and wiring had been pulled off.
    Now i wish to know how to use the output connection which has 3 wires, i noticed the first two output wires connected to third leg of transistor pcr406 while the 3rd output wire is connected to live or neutral. This is a 220v ac setup. How and which wires do i connect to the neon bulb? Hope someone can help point me to the correct way. Thank you.
    • 31002
    Re: Help identify Christmas light wiring
    interesting!
    they arent neon, they are 6v or 12v bulbs in series to total 240v
    the "transistors" are probably triacs or scr's and are the 2 outputs - you have 2 sets of lights so it can flash between them.
    what i find interesting is the pcb has space for 4 channels! - i wonder if they pulse or if you need different software??
    • R_J
      • 9535
      The pcr406 is a 0.8Amp/400v scr, the load in this case will be a number of incandescent lamps whose voltage total the input (220vac) The controller is a 8 sequence controller, and with the addition of 2 more scr's should control 4 channels.
      I have a blown 16 sequence Christmas light controller just like this but the chip on board is bad.
      • mikey5791
        • 515
        • Malaysia
        Originally posted by stj
        interesting!
        Hi stj,
        Say if i have a string of 20pcs 12v bulbs in series= total 240v, then i just connect one end to the output from first scr and another end to the common line. If i got an extra set of the same 20pcs bulbs, i need to connect one end to the output from the second scr and another end to the common line. Is the above correct as i do not wish to trip the house ac line. In addition, is there any part of the pcb that i can add a fuse or some diode to prevent over current or short circuit?
        Appreciate all your response and helpful comment. This forum had been a very resourceful place to ask for these electrical querries.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Eiew COB...
            • 31002
            Originally posted by mikey5791
            Hi stj,
            that's correct, you can just use a couple of sets of standard x-mas lights wired as you guessed.
            as for a fuse, inline with one of the incoming mains wires.
            infact to make it safe, replace the mains cable with a flat one that has 2 layers of insulation - chop an old radio lead or something and that gives you the plug and cable in one move.
            • shovenose
              Christmas Light Power Supply Question
              by shovenose
              I have a cheap rainbow christmas light set off Amazon which has this little power supply that has a button to change modes. I had a white set with the same power supply that I returned but I can't find any other rainbow themed ones that don't use this setup.
              Anyway, the problem is every time you unplug them and then plug them in it reverts back to "Combination" mode which cycles through all these annoying tacky effects instead of going back to what you had selected or at least defaulting to "Steady on" which is what I want. So I'm thinking I can just...
              12-08-2023, 09:59 AM
            • edugimeno
              Help me identify the missing component... Sound to light circuit
              by edugimeno
              hI there!
              Im trying to help a friend repairing a large, real-sized short-circuit robot.
              This is remotely controlled and has a 2 way voice send/receive. Also while the hidden operator is talking, the red bulb inside the "mouth" should flash according to the sound
              Some other technician used to service it and he was fired leaving all the repairs unfinished and no documentation at all.
              What I found is a sound receiver, a speaker, and a wire directly to the mought bulb (a normal motorbike 5W 12V bulb).
              So I bought a simple 2X30W amplifier to feed the loudspeaker...
              02-14-2024, 10:23 AM
              Lithonia Lighting versus Light of America Compact Fluorescent product quality
              by sam_sam_sam
              I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
              I also have back when Light of America had these light bulbs available for yard lights
              The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
              While the Lithonia lighting fixture has all most certain bulb failure
              So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
              I have only had this light fixture for not more than a year if it...
              07-02-2023, 03:45 PM
              LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
              This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-07-2024, 03:40 AM
              LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
              This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 09:10 PM
