Has anyone seen this ic chip used before LED Driver. BP2867CJ
    • Jul 2011
    • 6040
    I bought this LED lamp that uses this ic chip
    This light is bright as shit each LED light pad has one of these ic chips the board is nicely designed and layout
    Re: Has anyone seen this ic chip used before LED Driver. BP2867CJ
    BP Semi: http://www.bpsemi.com/en/product.php
    They probably over drive the LED's as usual.
      • Jul 2011
      • 6040
      I found out what voltage that these LED modules 48 volts @120 milliamperes this has decent light output
      At 280 milliamperes the voltage is 52 volts and that where the LED light is bright as shit
      They are the data sheet says this <280 milliamperes @ 72 volts
      I have some 48 volt at 300 milliamperes power supply’s which means that I can run two LED light modules on one power supply
        The question is, what are the LED Vf and If spec? It is got going to be easy to find out.
        120 mA should be OK, but not so sure at 280mA.
          • Jul 2011
          • 6040
          When powered at 120 milliamperes the heat sink only gets moderately warm but what I paid for it I not going to be overly concerned about it
          I have used this approach before and for most it has worked for me before
          Yes I agree with you about the 280 milliamperes is way over powering them because when you start going higher than the 48 volts the amperage goes up very quickly so I think at 120 milliamperes should be just fine
          I going to make a emergency room light with a 48 volt battery pack I just have to get a BMS board for this voltage
            Since you have been doing lots of works on batteries.
            Are you familiar with this BP-C3400,or what do you use to testing/charging Li-ion?
            I am thinking about getting battery tester since I have lots of batt from laptops to play with.
              • Jul 2011
              • 6040
              Yes I am familiar with this type of charger it okay but it is not going give you all the data you need to put a well balanced battery pack
              Now on the other hand if you were to buy this battery tester this unit would give you all the information you would ever need to make a balanced battery pack for a BMS balancing protection board controller to work correctly
              So let say that you have a real voltage drop start happening at 3.5 volts well most BMS boards there cutoff voltage can be some where 3.5 to maybe 2.8 volts now if it around 3.0 volts this still a problem if one battery run is 10 minutes shorter than the rest and the voltage roll off curve is 3.5 volts now the 10 minutes have turned into maybe more like 30 minutes to maybe an hour
              https://www.ebay.com/itm/EBC-A10H-El...53.m2749.l2649
              Yes this is a little bit pricey but it does what it says it does but there is a little bit of a learning curve to use it correctly
              The way to use it correctly is to set your cutoff voltage on discharge mode to 2.5 volts the first time you do a discharge test because you want to see what each battery discharge curve is because they can be some what different and the run time can also be different so you have to match as close as you possibly can for the best run time results
              Now with this battery tester machine you can cart each battery and compare them to get the best results
              Now you do have to use a computer to be able to cart the battery results
                Thanks, I will find the user manual and study it.
                  • Jul 2011
                  • 6040
                  There are some issues with the manual in the respect that there are some thing that it not real clear about and some thing that it make you think that you can do it but not quite correct about the way it written
                  Just keep this in mind when reading this manual
                  Here is the manual
                  • leyecoIII
                    • Aug 2020
                    • Philippines
                    Hi, this is maybe off topic. but this is my first forum post. i just saw your signature and found links that are useful. thank you
                    sorry if i replied in this thread.
                    br, ph
                      • Jul 2011
                      • 6040
                      br, ph
                      Welcome to the forum
                      This is the place where to learn a lot about a lot of things
                        • Jul 2011
                        • 6040
                        Did you decide to buy one of these battery tester machine if you did which one did you buy
