Help about Reflowings explanation
  • bohaboha
    • Nov 2012
    • 972
    • sweden
    Hi please help me whith a clear explanation of the reflowing action.It is only heating the circuit in question or a high heating so that soldering reaches the degree of melting.
    please if you can be as specific as possible with the whole procedure and what heat degree to use in general but in my case it concerns a Samsung tv mainboard.
    I've seen several youtube videos but none that clearly explain the momemts or degrees of heat and time needed thank you
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Help about Reflowings explanation
    https://en.wikipedia.org/wiki/Reflow_soldering
    • bohaboha
      • Nov 2012
      • 972
      • sweden
      Thank you
      • EasyGoing1
        The best way to drive a heating element?
        by EasyGoing1
        I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
        What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
        This is the general setup that I have now.
        This is what the...
        01-25-2023, 11:29 AM
      • Cemal Odabasioglu
        MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
        by Cemal Odabasioglu
        I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
        Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
        Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
        Observations...
        01-14-2025, 03:54 PM
      • dumblejd
        rtx 2080 GPU capped at 60 degree
        by dumblejd
        My friend has a evga rtx 2080 super, and with liquid cool backplate. I installed for him. 4 month ago it runs good, and recently idk if he played with msi afterburner or not, the gpu slow it's core frequency when it's over 60 degree. I reset setting in msi afterburner, still the same.
        here is a video of it running stress test, the usage is always 100% for sure, but core frenquency drop to 300mhz (should be over 1600mhz normally), when it hit 60 degree.
        https://imgur.com/a/gLMfJid
        at very beginning of stress test, the frequecy can reach 1600+, but as...
        12-11-2022, 11:17 PM
      • sew333
        Apartment to buy with coal heating. Any sense to buy electrical heater and new pc?
        by sew333
        Hi guys. I have an question. Overall i am currently selling my house ( apartment with 1 room ) to buy some cheaper with 1 room too, and save cash for new pc in autumn 2024.
        So i choosed some cheaper apartment in smaller city,but there is coal heating. I dont wanna heat for coal.
        So i m thinking to buy electrical heater. And my question . Is this any sense to buy electrical heater when i will be using new pc with rtx 5090 and new intel ( when will be released ) ultra + Psu Seasonic 1600W?
        I expect that i will pay more for bills. But i wanna know this. Will using electrical...
        06-14-2024, 07:30 AM
      • Curious808
        LG LST5651SW stove: oven not heating properly
        by Curious808
        LG LST5651SW stove: The oven has a hidden bottom (bake) element that seems not to be heating up, but tests OK.
        PROBLEM DESCRIPTION: Set oven to 400. The display shows it heating up normally to about 365, and stops there. The top (broil) element is visible and heated. Can't see the bottom element, but the bottom of the oven isn't extremely hot. A wet cloth on the bottom doesn't sizzle and doesn't really heat up. The stovetop burners seem to be working fine.
        TESTING SO FAR:
        1) Removed the back panel and leads to the bottom element. Using multimeter, continuity...
        01-07-2023, 02:37 PM
