Reuse the autotransformer of a 220-110V stepdown
  • Hitto
    • Apr 2019
    • 95
    • Italy
    I would like to reuse the autotransformer of this device, which converts 220 to 110 and claims to be bidirectional.
    This transformer has 0-220V inputs and 3 output wires. One goes to a diode in the PCB, the other one is output, the third goes through a relais which then goes to outputs.
    It seems to be a common design in these kind of converters but I can post more photos if needed.
    Do you guys know if the autotransformer in these step-down can be used for straight 220-110V conversion, bypassing the circuit?
    • Jul 2011
    • 6057
    Re: Reuse the autotransformer of a 220-110V stepdown
    This depends on whether or not it does setup and step down but sense you said that it bidirectional input/output are reversible then I think that you but you would have check how the winding are wired to really know for sure what type you have
      What is the make and model of that unit?
      Also provide pictures of the whole unit and full PCB top and bottom side.
      • Hitto
        • Apr 2019
        • 95
        • Italy
        The unit is quite generic and not available currently on eStores for a comparison.
        The PCB is marked LLD57/040ASC.
        FRONTAL:
        REAR:
        TRAFO (TRANSFORMER):
        They made a mess of wires with identical colours. Howewer the PCB is clearly marked with AC-IN (220V), OUT (110V), OUT (next to 512#).
        • Hitto
          • Apr 2019
          • 95
          • Italy
          Judging by the connections, but I am not sure about blue wire:
            • Jul 2011
            • 6057
            Are the winding interconnected or they isolated from each other
            Do you know how to check this ?
            Which side is the winding connected to the 110 volt side or the 220 volt side
            • R_J
              • Jun 2012
              • 9578
              The blue wire is likely a low voltage winding that supplies D1 and (35v) filter cap. The other end of the blue winding likely connects to yellow or red. You need to check the resistance of the windings to see how the transformer is wound.
                Originally posted by r_j
                the blue wire is likely a low voltage winding that supplies d1 and (35v) filter cap. The other end of the blue winding likely connects to yellow or red. You need to check the resistance of the windings to see how the transformer is wound.
                +1
                  "The unit is quite generic and not available currently on eStores for a comparison.
                  The PCB is marked LLD57/040ASC."
                  Obviously it's not generic autotransformer setup since it has active circuit with relay in it.
                  How about the external pictures of the box? It should have model number and some marking on the box itself.
                  Since it has relay (12V winding) and powered by one of transformer winding, then it not just a passive autotransformer setup.
                  Where do the whites wires go to? Neutral for the in let and neutral for the inlet and nothing else?
                  Autotransformer for step or step down will have Neutral direct connection between input and output.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Interesting, this would be the first...auto switching? step up/down transformer that I've seen...
                    Did it automatically detect input voltage and switch the outputs accordingly? Seems like it should...
                    I have two step up/down autotransformers, neither of them are auto-switching, I have to flip a jumper to set the input voltage.
                    Is there a reason not to use the circuit? Or is it for some other purpose or perhaps the circuit is defective?
                    • Hitto
                      • Apr 2019
                      • 95
                      • Italy
                      Yes, it automatically switches between 110 and 220VAC.
                      This is a close-up of the unit:
                      I was hoping to use the transformer without the circuit as the PCB has too many lifted pads.
                        • Jul 2011
                        • 6057
                        I do see any reason could not use this transformer but you have to answer a very simple question how is this transformer wired then you will know how you could use it
                          He needs to read post #7 to find out how each winding is.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            I would hope that the two white wires on the transformer are actually connected together internally, so either can be used. In an autotransformer, one wire is shared between input and output, which would be the two white wires. Then just ignore the blue wire which is used for the auto switching...
                            This sort of makes me want to build an autoswitching circuit for my step up/down converters, alas, the chances of me using it for step down is very unlikely.
                              OP should find out how the Neutral for the Inlet and Outlet are wired up.
                              BTW, how much power do you need for the load? The unit that you have is rated at only 40W as printed on the unit.
                              • Hitto
                                • Apr 2019
                                • 95
                                • Italy
                                40W should be enough as this unit will be used mainly for testing.
                                I have another one but it is sealed. Planning to open it with wires intact so you guys can check if it is indeed reusable without the circuit.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  If you're not sure, just get another 12VAC transformer and hook it up to any two wires, with the exception of probably the two white wires together. Measure all you want, and that will be easy to find the remaining wires...
                                  • jasakl
                                    Panasonic Toughbook HDDs with hard drive encryption - how to reuse them?
                                    by jasakl
                                    Dear community,
                                    i have searched the internet but i dont found a working solution for my problem:
                                    I have about 150 hard drives (mostely from hitachi 160gb HTS543216L9SA00) from Pansasonic CF-19 MK3 Notebooks.
                                    All devices had a BIOS Password and HDD encryption enabled.
                                    Now i try to reuse the HDDs, but i cant format them. I already tried windows Diskpart with argument "attributes disk clear readonly" but it says "cant delete" and i tryed several partition and low level formatters (like partition wizard, AOMEI and Easus).
                                    But all of...
                                    05-01-2024, 02:41 AM
                                  • edith
                                    Stepdown ASUS s530FN
                                    by edith
                                    Hello everyone. My laptop is dead, and i found out that the Stepdown is gone.
                                    Im trying to buying a new one.
                                    This is what i get from the scheme:
                                    RT8249CGQW
                                    And what i see on the IC itself is
                                    2n=5j
                                    J05
                                    I see many stepdowns online to buy if i type RT8249CGQW but noone has 2n=5j
                                    Most of them are 2n = 2j or other stuff.
                                    Can i buy them?
                                    Also, can anyone explain me what 2n = #J means?
                                    03-04-2023, 05:03 AM
                                  • harp
                                    how to protect autotransformer
                                    by harp
                                    I am planing to build all in box variac, isolation transformer and current limiter, and just want to ask, if is current limitted like 1A, and on variac is set low voltage, is there something circuit or design that prevent variac, ammeter or fuse to burn? Say to test some device, starting from 0v, while ocasionaly get shorted......
                                    10-18-2024, 10:14 AM
                                  • Bubbsy 2002
                                    Need Help indentifiying this autotransformer
                                    by Bubbsy 2002
                                    Hi all, need help identifying this auto-transformer manufacturer.
                                    It belongs in a Venmar EVO5 700 Hepa HRV, that was toasted by 180v power surge (Newfoundland Power).
                                    I have been able to repair other items that were destroyed i.e. my doorbell with doorbell transformer, my Husky Central Vacuum (used a doorbell transformer to fix too).
                                    So I am just assuming this is the case with this as the board looks perfect and fuse on it was not blown, but no power.
                                    Any help in this regards would be greatly appreciated.
                                    Thanks,
                                    01-01-2024, 02:48 PM
                                  • kaput
                                    Raspberry Pi 4, probable short onboard
                                    by kaput
                                    A few days ago, I smelled magical smoke, but couldn't pinpoint the source. Now when trying to 3D print something, Octoprint wouldn't respond, and I soon found that the stepdown powering the RPi 4 running Octoprint had burned out. Assuming that was where the smell came from.
                                    No idea if the stepdown failed and took the Pi with it, or if the Pi failed and took the stepdown with it.
                                    Measuring resistance between ground and the 5V line on the Pi, I get 0.2 ohms, more or less a full short.
                                    There's no visible damage to the RPi, checked the circuitry around the power...
                                    07-20-2024, 03:18 AM
