Stepdown ASUS s530FN
  • edith
    • Dec 2022
    • 31
    • Italy
    Hello everyone. My laptop is dead, and i found out that the Stepdown is gone.
    Im trying to buying a new one.
    This is what i get from the scheme:
    RT8249CGQW
    And what i see on the IC itself is
    2n=5j
    J05
    I see many stepdowns online to buy if i type RT8249CGQW but noone has 2n=5j
    Most of them are 2n = 2j or other stuff.
    Can i buy them?
    Also, can anyone explain me what 2n = #J means?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Stepdown ASUS s530FN
    2N= is the product code, the rest is date code. Check the data sheet.
    • edith
      • Dec 2022
      • 31
      • Italy
      Ok thank you. but is there any difference?
      How can i check if its what i want?
      • mon2
        • 14679
        No difference. Just purchase the one with 2N=. That is all.
        When a company builds the IC, they change the mfr datecode to match the batch.
        Often is the WEEK of the YEAR and the YEAR of the production.
        You can buy these from Aliexpress.
        https://www.aliexpress.com/w/wholesa...home.1000002.0
        Pick one with a high vendor rating and quick delivery to you.
        We typically use this vendor:
        https://www.aliexpress.com/item/3281...d=uqeE7URxbfIk
        • edith
          • Dec 2022
          • 31
          • Italy
          Thanks you a lot Mon2.
          I also noticed that a mosfet is gone. on schematics i have PQH8701
          On the mosfet itself i have m3092m 84687e.
          I found something only looking for the mosfet's label.
          Can you address me to what to buy regarding it?
          Thank you
          • mon2
            • 14679
            Certainly. The same vendor as linked above will have these parts.
            Reference:
            QM3092M6
            They will share a link and just compare the physical shape to your part. Should be identical. These are common mosfets out of Asia.
            • edith
              • Dec 2022
              • 31
              • Italy
              Thank you a lot!
              • edith
                • Dec 2022
                • 31
                • Italy
                Hello Mon2, thank u a lot for the answer! I already ordered it.
                But regarding the mosfet in the link. How did you find it was QM3092M6?
                Id like to learn. Because the label was m3092m. What does this label mean, and what does qm3092m6 means?
                How did u find it?
                To explain, i would not have buy it because its a different label.
                Thanks a lot
