Isolation Transformer Build - Technical Questions
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Isolation Transformer Build - Technical Questions
    Ah interesting, I would have thought the low cost units should be using EI cores as they're much cheaper to wind. Toroids, these are kind of tough...
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Probably you guys are right, it's an autotransformer with no isolation. They sold a lot off that listing on ebay and are not clear what they are selling - I do hope someone does not get killed
      As I already mentioned your best bet if you are in the UK is get two of the 110V portable site transformers and connect the secondaries in series (get the phase right)
      These transformers regularly turn up on ebay or gumtree second hand and sell for £20-£30 and give good isolation (they are specifically designed as safety transformers). You can also use two of these as 110V-0-110V
      Another good cheap source for very powerful transformers is scrap disco/club power amps. Get an old amp with linear PSU something like a 1200W - 1500W per channel and you will usually find a large toroidal with 90V-0V-90V or thereabouts. Old Peavey and InterM Amps and similar are a good source of these. That will give you 220V in 180V out at high ampage and that is close enough yes? plus you also have the input antisurge/filter, switch and power connectors to reuse.
      Follow me on YouTube
      Learn Electronics Repair
      • clearchris
        • Dec 2013
        • 687
        I'd rather repair an old amp! I'm always scavenging ebay looking for old peaveys, but they are going up in price...
        • dicky96
          Sun Seeker
          • Mar 2017
          • 1825
          • Spain
          Well yes Chris, but sometimes they are beyond fixing... I did fix my Peavey's and sell them before I left the UK. They were Class F or G - which is the type which switches the HT+ between about +/-45V and +/-90V rails on the fly?
          Anyway they had some damn good transformers in them. Mine just needed replacement main capacitors on both sets of voltage rails so were fixable
          • clearchris
            • Dec 2013
            • 687
            I can't imagine how bad they must be to be unfixable. Generally, they look like simple designs with simple parts. Don't know what kind they were, I just recapped them and replaced the volume pots. The pots almost always get busted in shipment.
            Probably true for other brands though. I only touch peaveys. They are reasonably priced and usually built solid.
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              #26
              Oh yeah they were Class G
              https://cdn.badcaps-static.com/pdfs/...3faf6720fd.pdf
              However I will bow to better knowledge (or morals)
              I recommend to go find some faulty/scrap old PA amps and in them you will find some very good transformers for the purpose of AC isolation 240V in 180V or so out
              But if by chance they are Peavey then send them over to Chris who will probably be very grateful and give you enough money towards a proper isolation transformer
              That should keep everyone happy yepp?
              • clearchris
                • Dec 2013
                • 687
                Heh, haven't bought any in a while, my favorite models seem to be well loved by others, and the price keeps going up on 20-30 year old peavey amps... Go figure.
                • harp
                  isolation transformer from two 240/12, wiring?
                  by harp
                  When is talk about making isolation transformer on poor-man way, always I see schematic 240/12-12/240.
                  So, I wonder, is this wiring from my attachment it work, bringing some good feature or it is bad idea and why?...
                  11-25-2022, 05:11 PM
                • ohren
                  Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                  by ohren
                  Hello!
                  I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                  Measured voltages with no load:
                  After rectifier diodes
                  12V: 6.17 V
                  5V: 5.67 V
                  Secondary transformer pins AC measurement (really don't know if this says anything)
                  12V: 2-2.5 V
                  5V: 1.04 V
                  I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                  03-18-2023, 10:33 AM
                • mikey5791
                  Is it possible for transformer substitution?
                  by mikey5791
                  Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                  Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                  My questions are
                  1. How do i test to see if the transformer is in good working condition?
                  2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                  Hope you guys understand what i was asking. My intention is...
                  11-03-2022, 02:11 AM
                • dennis_elx33
                  3PHASE STEP-DOWN Transformer in Check
                  by dennis_elx33
                  Hello All,
                  i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                  Problem statement: Power tripped Off
                  Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                  Action Done:
                  1) Replaced the faulty parts with good spare.
                  2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                  12-02-2024, 06:52 AM
                  ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                  This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 04:40 PM
