Are circuit boards toxic when exposed to heat?
  • caphair
    • Nov 2011
    • 1249
    I want to make a blade to clean underfill off of some mobile phone ics that's safer than metal (sometimes metal cuts through the solder mask or rips pads off)
    I have junk circuit boards laying around and I was experimenting with some. Managed to shape a knife tip attached to an x-acto blade handle that worked surprisingly well.
    However it does leave an odor when using which got me wondering about the materials used. Is there a health risk? If so does anyone have any suggestions on materials I could use that would work just as well without causing damage?
    • 31256
    Re: Are circuit boards toxic when exposed to heat?
    i dont think the fiberglass mat burns, but the epoxy may not be all that good.
    but your using it to remove epoxy anyway.
    why not use a ceramic?
    • caphair
      • Nov 2011
      • 1249
      Are all circuit boards made of fiberglass and epoxy? This one burns a little and chars.
      Ceramic is a great idea, but would it be sharper than metal and damage ics if too much pressure is applied?
        • 31256
        ceramic, like metal is only as sharp as you choose.
        most pcb's are fiberglass (FR4)
        but there is also paxoline - cheap brown crap that is often used for single-sided products
        i dont know what paxoline is made from.
        • Harvey
          • Apr 2007
          • 264
          Its epoxy bonded paper.
          • caphair
            • Nov 2011
            • 1249
            The one I used must be paxoline as it burns like paper. Is the epoxy used toxic?
            How could you tell if a circuit board is paxoline or fiberglass?
              • 31256
              paxoline cracks,
              fiberglass - if you snap it you will see the fibers
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8703
                It's purely the epoxy and the fire resistance compounds mixed in the epoxy that's toxic, but the idea that the epoxy and fire resistance compound will self extinguish when brought to flame. The paper in FR2 will burn like any other paper.
                If you remove/scrape off the soldermask on the board portion, FR4 fiberglass is greenish/translucent due to the fiberglass (though the multilayer soldermask will disguise it). Sometimes if you scrape off an edge you can see the fibers, and if you run your fingernail across the edge, it will snag and rip your fingernail as glass is harder than keratin. FR4 is very stiff.
                FR2 phenolic paperboard/paxoline is opaque and layered. It will flex and crack when bent, and when it cracks and breaks, you'll see it split how mica splits as it's similar in composition. Typically FR2 is whitish/brownish when the soldermask is removed.
                If you have some prototyping board that has a whole grid of holes drilled in it, chances are it's FR2 to keep things cheap. It will be brown colored. This is not to say that there's no FR4 prototype board - FR4 prototype board is much more expensive, and typically it will be greenish translucent, again if it doesn't have green soldermask on it.
                • caphair
                  • Nov 2011
                  • 1249
                  Great info thanks. So it seems the one I shaped into a knife was FR2. Is there any toxic risk the way I'm using it? Hot air used is around 250-300c. The charring must be the paperboard being burnt but what about the epoxy and fire resistance compound be air born as well?
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8703
                    Well FR2 was not meant to be heated at all. I'm surprised it lasts at all, this stuff is weak.
                    If I frequently have to heat the thing so that it charcoalizes frequently, I'd probably refrain from doing so, but if you infrequently do it, it's probably okay.
                    • caphair
                      • Nov 2011
                      • 1249
                      Thanks again. Any health risk using FR4 in this fashion? At this point I'm more curious for reference. I may opt for a ceramic alternative
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8703
                        They both basically use the same kinds of things, if you're heating them up to charcoalization point, you're releasing the flame resistance molecules and this is the nasty stuff.
                        FR4 is kind of dicey because if you sharpen it to a point (it'll be hard because of the glass fibers) you'll still get fibers pointing out of the bulk... may or may not be fine, but definitely a scraper...
                        • ugamazing
                          by ugamazing
                          12-17-2024, 07:05 PM
                          Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                          The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                          Securing a good thermal interface between...
                          10-07-2024, 04:35 AM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                        • VitalComputing
                          Taking Pictures Of Large Circuit Boards
                          by VitalComputing
                          Hi friends,
                          I am trying to take good quality pictures of rather large desktop motherboards for a project I'm working on. I had a brilliant idea of scanning them with a flatbed scanner I have but it only focuses on the bits of the board that are flush to the scanning glass. And the through hole components tend to lift the main board from the scanning glass. Everything else just looks out of focus. So it seems that that option wont run.
                          I have been capturing the images with my iPhone 11 and it's okay but wont capture the whole board. I have to grab it in sections and...
                          11-22-2022, 04:15 PM
                        • Astonished
                          Fixing the Charge Circuit of the Batteries of the DC Motor
                          by Astonished
                          Hi friends of electronics
                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                          Please help me fix this circuit.
                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                          01-28-2025, 06:24 AM
