Micro inverters
  • wozzie
    • Dec 2014
    • 21
    Micro inverters
    Just wondering if anyone here has played around with Enphase M215 micro inverters . Just would like to know if there is a way to communicate with these inverters without the envoy module .
    Any help would be much appreciated
  • Taurus12
    Optiplex 3050 micro 2 blinks followed by 3 blinks issue
    by Taurus12
    Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
    I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
    i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
    Any recommendation on what I have to do next? Thanks in advance
    06-10-2025, 05:05 PM
  • Isabella91
    Possible to convert eMMC Socket to a micro SD Card socket?
    by Isabella91
    I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
    Read/Write a Micro SD Card from an eMMC Socket.
    I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
    Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
    Not to remove...
    01-14-2024, 05:10 PM
    Design of CCFL Backlight Inverters with Frame & Bar Cores
    Summary
    Portable devices, such as notebook computers and personal digital assistants are developed rapidly nowadays, which places an increasing demand on display technology. The LCD with cold cathode fluorescent back lighting satisfies the requirements on display performance, size and efficiency.
    The backlight inverter plays a crucial role in supplying the power to the lamps of these flat-panel displays.
    The frame and bar ferrite cores, described in this brochure, are especially designed...
    10-07-2024, 04:26 AM
  • Stunt
    Dell Optiplex Micro 7010 Computrace
    by Stunt
    Device: Laptop
    Brand: Dell
    Model: Dell Optiplex Micro 7010
    Board : 212045-1
    S/T : 2RP6VX3
    Request : Computrace Unlock
    08-12-2025, 06:15 AM
  • Altemon Moura
    Optiplex 3000 micro
    by Altemon Moura
    Unfortunately, when removing the chip
    (GIGADEVICE 25R256EYIG)
    It broke in the hot air.
    Will I be able to buy this same model?
    (GD25R256EYIG)
    "Can I burn the Bios?"
    motherboard
    DELL Optplex 3000 - 202040-1 D10NK$HA
    Optiplex 3000 micro
    Service tag: C7CG7T3
    SERVICE CODE: 26565563271​
    05-20-2025, 06:35 AM
