Here is something that might interest you DC Multifunction LCD Panel Meter
    • Jul 2011
    • 6059
    I found these in an email that I get from MPJA
    https://www.mpja.com/DC-Multifunctio...info/36139+ME/
    You might be interested in this one as well
    https://www.mpja.com/Dcdc-adjustable...info/36146+PS/
    You might also be interested in this one as well
    https://www.mpja.com/Boost-Buck-DC-D...info/36140+PS/
    I have bought one of each to try out for a lithium ion battery charger controller
    • 31165
    Re: Here is something that might interest you DC Multifunction LCD Panel Meter
    a friend has the first meter - he wasnt impressed with the lcd viewing angle.
      • Jul 2011
      • 6059
      In general the LCD displays that have backlights have this problem unless you pay a lot for the display even then you are limited by how far you can see display at angle on the sides or up and down view
      So the real question is how well does it work besides the viewing of the display
        • 31165
        it does what it says on the box pretty much.
        thing is, if it's on a bench and your above or below it you cant read it well.
        oled is the way to go.
        • howardc64
          LG 49UJ6500 LCD panel lighter band that goes away
          by howardc64
          49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
          Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
          02-19-2023, 12:13 AM
        • triplefour
          SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
          by triplefour
          TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
          tcon is built into mainboard.
          Only one cable goes to panel boards.
          there is a cable from one panel board to the other that links them.
          cost cutting measure that results in us having harder time to diagnose.
          removing the link to the second panel board allows TV to stay on with stable backlight but no image.
          used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
          07-28-2022, 07:59 PM
        • Storyteller12
          QN55Q60R Service Menu Panel Help
          by Storyteller12
          I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
          I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
          I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
          the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
          01-13-2024, 01:57 PM
        • maneatingmonkey
          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
          by maneatingmonkey
          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
          03-27-2024, 07:17 AM
        • chth96
          by chth96
          03-09-2024, 10:03 PM
