Digi-Key caps
  • Maluko75
    • Aug 2009
    • 36
    Digi-Key caps
    Difference between the eb and fc series?????
    master hoarder
    • May 2008
    • 12175
    Re: Digi-Key caps
    I think FC has lower ESR and higher ripple current handling capability.
    • Toasty
      • Jul 2007
      • 4171
      Re: Digi-Key caps
      You mean Panasonic caps that you can get from Digi-Key.
      EB Specs:
      FC Specs:
      IMO, EB's are long life caps of the "General Purpose" type. Ripple handling is mediocre at best at around 20% of an FM's capability, and 25% of an FC's. EB's are limited in the values available compared to many other series, and do not have a 6.3v variety at all.
      Toast
      veritas odium parit
      • Maluko75
        • Aug 2009
        • 36
        Re: Digi-Key caps
        So they wont work on a power supply?
        • Toasty
          • Jul 2007
          • 4171
          Re: Digi-Key caps
          Correct. Not suitable for SMPS.
          Toast
          veritas odium parit
          • Maluko75
            • Aug 2009
            • 36
            Re: Digi-Key caps
            Hey thanks toasty I went ahead and got the ones that are needed,been ahwile since i fickle with electronics....
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Re: Digi-Key caps
              As long as you don't POP Fickle with electronics you're doing fine.
              Mann-Made Global Warming.
              - Dr Seuss
              • Toasty
                • Jul 2007
                • 4171
                Re: Digi-Key caps
                veritas odium parit
                  by momaka
                  03-12-2025, 03:42 PM
                • quickname
                  Cyberpower 1500AVR UPS repair
                  by quickname
                  I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                  I decided to verify that the batteries were...
                  11-12-2023, 09:57 AM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • Bugmanscj
                  Audio Linear Power Supply (LPS)
                  by Bugmanscj
                  Hi: Found this forum fumbling over the net looking for replacement capacitors for a high quality 2uv ripple model Kaia, Core Audio Technology LPS. I bought it used on fleabay and figured I would have to recap and sure enough one of the 22,000uf 35V 105c caps is bulging. These supplies were made briefly around 2014 for MAC Mini audio servers, and were quite costly at the time ($1.7k), you know it's audio... I will use it for a video processor power supply to replace a switched version. I figure it's a low cost attempt to see/hear what difference it might make in my system. Plus I get to learn...
                  02-17-2025, 08:50 AM
