Component identification
  • sasam
    • Nov 2019
    • 16
    • Croatia
    This little element is marked 54B1G
    is it some kind of power switch for usb?
    I can't find anything online.
    I burned the USB port when I connected 12V to 5V by mistake. I replaced the tantalum capacitor and now the USB is working but my resistances between VBUS and GND on that USB port are doubtful. Something else is probably damaged.
    • 31151
    Re: Component identification
    aat60054b-s5
    maybe
      • 21446
      The part is a Seiko S-1339D15-M5T1U3 ,you can use a silergy SY6288C20AAC as a replacement part .
      • diif
        • Feb 2014
        • 6978
        • England
        This listing suggests it's a G524B1 https://www.ebay.com/itm/10pcs-G524B...-/401903391376
          • 21446
          You`re right diif ,the part numbers i got were from russian forums .
          • sasam
            • Nov 2019
            • 16
            • Croatia
            Thanks!
            • sasam
              • Nov 2019
              • 16
              • Croatia
              There is another component to which I can't find anything online.
              It is marked with X1 and is connected in parallel with a tantalum capacitor and a small ceramic one.
              Can anyone help me identify this component?
                • 31151
                its a diode probably - the line at one end gives it away.
                • sasam
                  • Nov 2019
                  • 16
                  • Croatia
                  Yes it look like zener diode, or some kind of ESD protection diode but I cannot find specification.
                  • sasam
                    • Nov 2019
                    • 16
                    • Croatia
                    Could this be that diode?
                    https://cdn.badcaps-static.com/pdfs/...e424351f2d.pdf
                    • ChaosLegionnaire
                      cracked tantalum cap on a video card. safe to apply power without fireworks?
                      by ChaosLegionnaire
                      please refer to the attached pics. is it safe to apply power with that tantalum cap like that without causing fireworks? i dont wanna burn a hole through the pcb as the gpu chip is on the other side.
                      happened to me once before with a shorted mlcc. shorted mlcc on a vrm power phase burned a hole through the pcb power section but thankfully that was nowhere near the gpu chip. but the video card still ended up in the landfill anyway tho as the burn-through was not fixable.
                      so do let me know what u think of the chipped tantalum there. thanks....
                      09-08-2024, 07:05 PM
                    • Shulgin
                      Acer predator XB241YU Component identification
                      by Shulgin
                      I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
                      After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
                      In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
                      I...
                      05-11-2024, 11:06 AM
                    • thebomb602
                      ASUS GA402R IC identification
                      by thebomb602
                      Hey guys! my name is kyle, new to motherboard troubleshooting and a little confused still on chip identification if yall could help identify this chip..
                      also if you could teach me how to fish on this particular topic... i did read through the ic identification sticky, and couldnt identify this with that info... thanks!
                      EDIT, just realized thats a 5 and not an S in the first line... finding results for it now. cant figure out how to take down thread so im not embarrassed...
                      11-21-2023, 02:30 PM
                    • Tend0
                      hp elitebook 840 G4 no 5v IC identification
                      by Tend0
                      Hello everythone
                      i have on the bank hp elitebook 840 G4 6050a2854301 mb a01 missing 5V cause IC is damage on this board 5V and 3V IC is separatly
                      i have 3V but no 5V i found 5V IC damage . i need our help to find IC identification, the 3v ic has mentionned ALVH 572 i found reference but no see something like IC . I poste the 3V here if someone have is reference. i don't found motherboard schematique or boardview...
                      05-31-2025, 09:13 PM
                    • Tomylee
                      Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
                      by Tomylee
                      I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
                      It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
                      I'm looking for help with the following:
                      The exact identification or part number of the T5 component
                      05-28-2025, 12:42 PM
